clue_display_sensor_data.py not working
by capnfantasy on Sun Mar 08, 2020 1:30 pm
This was discussed on discord and it seemed helpful to add it to the forums. The clue_display_sensor_data.py from the examples did not work on my new Clue board, I was getting the error: Traceback (most recent call last):
File "main.py", line 1, in <module>
File "adafruit_clue.py", line 917, in <module>
File "adafruit_clue.py", line 172, in init
RuntimeError: SDA or SCL needs a pull up
capnfantasy
Re: clue_display_sensor_data.py not working
by adafruit_support_carter on Sun Mar 08, 2020 1:38 pm
Thanks. Can you also post the text you got, including the banner that shows the firmware version information, when you ran this test via REPL:
Adafruit CircuitPython 5.0.0 on 2020-03-02; Adafruit CLUE nRF52840 Express with nRF52840
>>> import board
>>> i2c = board.I2C()
by capnfantasy on Sun Mar 08, 2020 2:04 pm
>>>import board
>>> i2c = board.I2C()
  File "<stdin>", line 1, in <module>
capnfantasy
by capnfantasy on Sun Mar 08, 2020 2:30 pm
This may have been fixed with a power cycle.
capnfantasy
by adafruit_support_carter on Sun Mar 08, 2020 3:52 pm
Interesting. There's a chance it could be related to power. On discord you mentioned using your computers USB port. That should generally be OK, but the USB cable itself could even be a potential issue.
Go ahead and just keep using the CLUE. If the problem shows up again, see if you can correlate it to anything.
by kevinjwalters on Mon Mar 09, 2020 4:53 am
I doubt it's a factor here but I've accidentally placed a CPX board on a conductive service before and I think that was linked with a problem like this. The round flat boards with the conductive pads on both sides are most vulnerable to this, the CLUE has a fairly large exposed edge connector but doesn't lie flat.
Dan Halbert alerted me to GitHub: adafruit/circuitpython: I2C Bus error leaves board unrecoverable without power down #2635 - the essence of that is no particular trigger for the rather random problem plus solution/workaround is a power-cycle.
kevinjwalters
