Problems (and fixes!) for build tools
by axiomatic on Sun Mar 15, 2020 2:04 pm
I ran into a couple errors in the course of getting my laptop configured to build CircuitPython from source. I'm leaving the steps I followed here in case anyone else gets stuck.
1. When I ran make, there was a missing library (adafruit_usb_descriptor). I looked in the tools directory and found an empty directory called usb_descriptor. I renamed the directory to adafruit_usb_descriptor and downloaded the library from this link https://github.com/adafruit/usb_descriptor and put the files in the renamed directory. That fixed the first problem.
2. The second problem was another missing library in /tools/uf2/util/uf2conv The fix was to download the missing files from this link https://github.com/microsoft/uf2, create the folder structure (on my machine I had make the folder structure /uf2/util/uf2conv inside the tools directory), and add the downloaded library to the new folders.
Hopefully this helps someone else who runs into these problems.
axiomatic
Re: Problems (and fixes!) for build tools
by jerryn on Sun Mar 15, 2020 4:34 pm
Just to be sure - did you run all of these commands before building?
git clone https://github.com/adafruit/circuitpython.git
cd circuitpython
git submodule sync
git submodule update --init
git submodule update --recursive
from https://learn.adafruit.com/building-circuitpython/build-circuitpython
jerryn
by axiomatic on Sun Mar 15, 2020 4:58 pm
I'm embarrassed to say I can't reproduce the error. I tried the build setup process from the beginning and everything worked perfectly. Oh well, disregard.
axiomatic
