Trouble importing neopixel and and cpx libraries
by MillenniumThalken on Sun Mar 15, 2020 5:07 pm
I am using the CPX and CircuitPython, trying to play some WAV files and LEDs on a button push. Currently I have two buttons and a STEMMA speaker connected to the CPX, I want to trigger one of the on board LED's when I push the button to play a WAV file.
if I import just the circuit playground express library I can play the WAV files:
from adafruit_circuitplayground.express import cpx
if I import just the neopixel library I can get the lights working
import neopixel
but if I do them together I get the following error:
File "code.py", line 12, in <module>
           file "neopixel.py", line 91, in __init__
           ValueError: NEOPIXEL in use
here is the rest of my code:
# Circuit Playground NeoPixel
# this is an exampleof using two buttons to fire the on board
import time
import random
import board
import neopixel
import audioio
from digitalio import DigitalInOut, Direction, Pull
pixels = neopixel.NeoPixel(board.NEOPIXEL, 10, brightness=0.4, auto_write=False)
RED = (255, 0, 0)
YELLOW = (255, 150, 0)
GREEN = (0, 255, 0)
CYAN = (0, 255, 255)
BLUE = (0, 0, 255)
PURPLE = (180, 0, 255)
WHITE = (255, 255, 255)
OFF = (0, 0, 0)
button_1 = DigitalInOut(board.A4)
button_1.direction = Direction.INPUT
button_1.pull = Pull.UP
button_2 = DigitalInOut(board.A2)
button_2.direction = Direction.INPUT
button_2.pull = Pull.UP
# pixels[1] = RED
# pixels.show()
while True:
    if not button_1.value:
        randNum = random.randint(0,2)
        if randNum == 2:
            cpx.play_file("blaster1.wav")
        elif randNum == 1:
            cpx.play_file("blaster2.wav")
        elif randNum == 0:
            cpx.play_file("blaster3.wav")
        print(randNum)
        # pixels.show()
    if not button_2.value:
        cpx.play_file("prep.wav")
MillenniumThalken
Re: Trouble importing neopixel and and cpx libraries
by adafruit_support_mike on Mon Mar 16, 2020 1:05 am
[moved to the CircuitPython forum]
by tannewt on Mon Mar 16, 2020 12:28 pm
Hi MillenniumThalken, the Circuit Playground library instantiates the neopixels for you already. They are available as `cpx.pixels`. No need to `import neopixel` yourself.
tannewt
by MillenniumThalken on Tue Mar 17, 2020 8:44 pm
That was the trick! Thanks I got it working.
MillenniumThalken
