Adafruit Industries, Essential service and business: NYC – Executive Order 202.6 - Read more.
CP 5.0.0 on STM32F411-Discovery USB Drive Space
by rando on Mon Mar 23, 2020 3:25 pm
Howdy All,
Easy stay at home project today, I got an old STM43F411-Discovery board out of storage, updated the way out of date ST-Link firmware and quickly uploaded the latest 5.0.0 Circuit Python image, using STM32CubeProgrammer 2.40.
Read to flash CP 5.0.0 STM32F411-Discovery.JPG (186.29 KiB) Viewed 18 times
Powered down, and back up everything and was delighted to see the CP drive instance spring up pronto. Just that easy.
But there's only about 28+ K of drive space which is not enough load the latest library support files to do a test of the onboard, acceleration/mag sensor.
Any ideas how to increase the memory in flash for the CP virtual drive?
rando
Re: CP 5.0.0 on STM32F411-Discovery USB Drive Space
by tannewt on Mon Mar 23, 2020 4:30 pm
Glad you got it going so easily!
Unfortunately it isn't easy to make the drive larger due to the non-uniform erase sizes of the internal flash. (If the discovery board had external flash this wouldn't be an issue.) The 411 has 4 16k sections of flash, one is used for ISRs and the last three are for the filesystem. There is one 64k block as well but it would take half of ram to buffer. The remaining ones are 128k which would exactly fit into RAM (leaving no space for CircuitPython.) More info here: https://github.com/adafruit/circuitpyth ... x_FLASH.ld
tannewt
