PyPortal: No CIRCUITPY Drive
by cr2n on Tue Mar 24, 2020 12:26 am
I was working on some code and suddenly the CIRCUITPY drive disappeared and I can not reach the drive any more. The TFT screen is black, the green LED is on, not pulsing. The red USB LED is on too, slowly pulsing.
I can reset the board and copy over the pyportal uf2 file but after PORTALBOOT disconnects, CIRCUITPY does not connect or appear.
I am running a Mac Mini with OSx 10.15.3 Catalina.
Using adafruit-circuitpython-pyportal-en_US-5.0.0.uf2
I downloaded the uf2 file again just in case my copy was somehow corrupt - no change.
I restarted the Mac and no change - I can reach PORTALBOOT after 2x clicking the reset button but then CIRCUITPY does not appear after copying over the uf2 file, again.
I also deleted all file contents (current.uf2, index.htm, info_uf2.txt), then copied over the uf2 file -still no change of behaviour and those 3 files were restored.
At the terminal, I also do not see the pyportal usbmodem device using command "ls /dev/tty* "
I was experimenting with circuitpython sockets at the time and this occurred after uploading a code.py that I was troubleshooting. Unfortunately, I did not save a copy to my local drive so I can not share all the code. I know the code was broken and was failing at a line where I forgot to add () after the function call when I last uploaded code.py. In my code.py, I declared an INET socket then the code failed at these lines. As I was troubleshooting, I added the first line below about line 12 of the file and I think this is when the device stopped working:
socket.active
socket.listen(4)
I appreciate any suggestions how to troubleshoot further. I only have a USB connector, at this time.
cr2n
Re: PyPortal: No CIRCUITPY Drive
by cr2n on Tue Mar 24, 2020 12:29 am
I should mention also that when I plug in the device, there is no boot sequence on screen. The device green LED turns on.
IF I reset the device, I then get the glowing red LED until the PROTALBOOT drive is disconnected.
cr2n
by tannewt on Tue Mar 24, 2020 12:54 pm
Does the red LED only show when the *BOOT drive is showing? What does the neopixel show otherwise?
Could you post a picture of the board?
tannewt
Specifically a picture of the back of the board, not the screen.
tannewt
by cr2n on Tue Mar 24, 2020 2:19 pm
Hello
This is the board when the PORTALBOOT drive is not mounted
This is the board when I first plug it in and the PORTALBOOT drive is mounted. The red LED is "breathing" so to speak, gradually increasing and decreasing in brightness, repeatedly.
Strangely, this morning, When I eject the PORTALBOOT drive from the OS Finder window, the drive removes itself and then immediately reconnects. I don't recall it doing that last night.
cr2n
by tannewt on Tue Mar 24, 2020 2:41 pm
It sounds to me that CircuitPython isn't correctly flashed after the bootloader. Slow red breathing LED along with green neopixel is the bootloader successfully connected to USB.
Try re-downloading the PyPortal UF2 and installing it. Maybe even try an older version if 5.0.0 doesn't work.
If that still doesn't work please post current.uf2 from the bootloader in a zip file. It'll include the contents of the flash and we can compare it to what it should be.
tannewt
by cr2n on Tue Mar 24, 2020 5:46 pm
THANK YOU
I downloaded version 4.1 uf2 and this brought back CIRCUITPY drive. I changed code.py to a simple print("Hello") and this successfully compiled.
I then reset PyPortal and applied 5.0-rc1 uf2 successfully and have CIRCUITPY drive.
Finally, I applied my previous project before I had gone tinkering with sockets etc and everything is back to where it was.
Cheers!
cr2n
by tannewt on Tue Mar 24, 2020 6:55 pm
Great! Does it work now with 5.0.0? It should be the same as 5.0.0-rc.1.
tannewt
by cr2n on Thu Mar 26, 2020 9:58 am
Yes the 5.0.0.uf2 version also works. I just applied it now and no issues. I must have done something unaware to cause my issue while tinkering with socket code. Thank you for helping me recover!!
cr2n
by tannewt on Thu Mar 26, 2020 3:55 pm
No problem! I'm glad it works!
tannewt
