Black Lives Matter - Action and Equality. ... Adafruit is part of the Stop Hate for Profit campaign. Adafruit is open and shipping.
PyGamer-Thermal_Camera-amg8833
by Rosebud on Thu Mar 26, 2020 8:43 am
The PyGamer_Thermal_Camera code fails at line 13, in <module> Import Error: no module named "adafruit_pybadger, PyBadger'. It fails using CircuitPython 5.0.0, or CircuitPython 4.1.2 and respective libraries. It appears adafruit_pybadger is looking for pybadger, pygamer instead of PyGamer and PyBadger, but if changed an error occurs in line 19 looking for PyGamer.
How do I correct the code? Help would be appreciated.
Rosebud
Re: PyGamer-Thermal_Camera-amg8833
by dastels on Thu Mar 26, 2020 9:03 am
Are you using the latest copy of the respective libraries?
Also, I advise you stick with 5.0.0.
The init for the library does some "magic" to import the appropriate submodule for the hardware it's running on.
dastels
by Rosebud on Thu Mar 26, 2020 9:49 am
adafruit-circuitpython-bundle-5.x-mpy-20200324 with circuitpython 5.0.0; it there a newer one?
adafruit-pybadger was dated 3/17/2020---AdafruitPyBadger Library Documentation Release 1.0
Rosebud
by dastels on Thu Mar 26, 2020 10:27 am
You have the latest.
What your CIRCUITPY/lib directory look like when fully expanded?
dastels
by Rosebud on Thu Mar 26, 2020 4:48 pm
Is this what you want?
lib folder has 6 folders and 5 mpy files.
folders
adafruit_bitmaps_font
_init_.py
bdf.mpy
bitmap_font.mpy
glyph_cache.mpy
pcf.mpy
ttf.mpy
adafruit_bus_device
_init_.py
i2c_device.mpy
spi_device.mpy
adafruit_display_shapes
circle.mpy
line.mpy
polygon.mpy
rect.mpy
roundrect.mpy
triangle.mpy
adafruit_display_text
label.mpy
adafruit_pybadger
_init_.mpy
clue.mpy
pybadge.mpy
pybadger_base.mpy
pygamer.mpy
adafruit_register
_init_.py
i2c_bcd_alarm.mpy
i2c_bcd_datetime.mpy
i2c_bit.mpy
i2c_bits.mpy
i2c_struct.mpy
i2c_struct_arry.mpy
mpy files
amg88xx.mpy
lis3dh.mpy
miniqr.mpy
neopixel.mpy
simpleio.mpy
Rosebud
by dastels on Thu Mar 26, 2020 5:32 pm
Yes, that's it. Everything looks as it should.
Can you past in the output from the REPL.
dastels
by Rosebud on Thu Mar 26, 2020 6:13 pm
code.py output:
File "code.py", line 13, in <module>
ImportError: no module named 'adafruit_pybadger.PyBadger'
Rosebud
by dastels on Thu Mar 26, 2020 7:02 pm
It should be pybadger, not PyBadger
dastels
by Rosebud on Thu Mar 26, 2020 7:52 pm
If you change line 13 to:
from adafruit_pybadger import pybadger
you will fail on line 19:
panel = PyBadger(pixels_brightness=0.1) # Set NeoPixel brightness
If you change line 19 to:
panel = pybadger(pixels_brightness=0.1) # Set NeoPixel brightness
code.py output:
File "code.py", line 19, in <module>
TypeError: 'PyGamer' object is not callable
I don't know where PyGamer came from, but I bet pybadger would be happy if it were pygamer, maybe.
Rosebud
by dastels on Thu Mar 26, 2020 9:33 pm
After looking through the thermal camera guide as well as the PyBadger code an examples, I think the library has evolved (and I do recall a lot of update messages regarding that library) while the guide code hasn't. Have a look through the examples (https://github.com/adafruit/Adafruit_CircuitPython_PyBadger/tree/1cf2d83c6e0471570535840fdf94431456926752/examples) and see what needfs to be changed. The actual library code is at https://github.com/adafruit/Adafruit_CircuitPython_PyBadger/tree/master/adafruit_pybadger. You'll want to look primarily at pybadger_base.py and pygamer.py
dastels
by Rosebud on Fri Mar 27, 2020 9:32 am
I replaced the latest adafruit_badger file with a version 1.1.1 for circuitpython 5x and it worked as the original PyGamer_Thermal_Camera code.
Dave thank you, and stay safe.
Rosebud
by dastels on Fri Mar 27, 2020 9:58 am
I love a good workaround. Have fun, and stay safe yourself.
dastels
by joseuzziel on Mon Jun 01, 2020 11:57 am
How can I get an average object temperature from AMG8833 by using a Python script?
I tried by reading "temperature" property, however, it changes very slowly, it seems to be ambient temperature.
i2c = io.I2C(board.SCL, board.SDA)
amg = adafruit_amg88xx.AMG88XX(i2c)
temp_object = amg.temperature
print(temp_object)
Thanks a lot for your gentle attention.
Best regards,
joseuzziel
by dastels on Mon Jun 01, 2020 3:19 pm
The temperature of the object it's pointing at? Ready the pixels with amg.pixels, iterate over the resulting 2 dimensional array adding the values, then divide by 64.
dastels
by qwertypoiuyt on Wed Jun 03, 2020 9:52 pm
I am trying to get the thermal camera to work on the pygamer. I read through the responses above from Rosebud, and I have the same errors he did, with line 13. I don't understand his workaround that apparently fixed it. I have the newest libraries and uf2 file downloaded. I tried a few older ones as well, but got the same errors.
qwertypoiuyt
