M4 Express with Prop-Maker not lighting NeoPixels
by MillenniumThalken on Thu Mar 26, 2020 8:22 pm
I am trying to rig up a Neopixel LED strip to a prop-maker feather wing that is on the M4 express. I thought I wrote a little CircuitPython to see if it was working, but I get no lights. Does this code look like it should be running a LED Strip or is there something wrong in my code?
from digitalio import DigitalInOut, Direction, Pull
import board
import neopixel
# CUSTOMIZE YOUR COLOR HERE:
# (red, green, blue) -- each 0 (off) to 255 (brightest)
# COLOR = (255, 0, 0)  # red
#COLOR = (100, 0, 255)  # purple
COLOR = (0, 100, 255) #cyan
NUM_PIXELS = 60
NEOPIXEL_PIN = board.D5
strip = neopixel.NeoPixel(NEOPIXEL_PIN, NUM_PIXELS, brightness=1, auto_write=False)
while True:
    strip.fill(COLOR)# Set to color
    strip.show()
MillenniumThalken
Re: M4 Express with Prop-Maker not lighting NeoPixels
by adafruit_support_carter on Thu Mar 26, 2020 9:12 pm
by MillenniumThalken on Fri Mar 27, 2020 6:10 pm
This is perfect, thanks so much.
MillenniumThalken
