Issue installing circuitpython-neopixel on RPi
by mtyeager on Fri Apr 10, 2020 10:26 am
I am having issues installing adafruit-circuitpython-neopixel on a RPi 3B.
I have installed everything listed on https://learn.adafruit.com/circuitpytho ... spberry-pi
When I then try to run: sudo pip3 install rpi_ws281x adafruit-circuitpython-neopixel
I get the following error message.
“Could not find a version that satisfies the requirement Adafruit-Blinka (from adafruit-circuitpython-neopixel) (from versions: ) No matching distribution found for Adafruit-Blinka (from adafruit-circuitpython-neopixel)”
Any suggestions?
mtyeager
Re: Issue installing circuitpython-neopixel on RPi
by tannewt on Fri Apr 10, 2020 2:20 pm
What version of Python are you using? That message usually means that the package is for a newer version of Python.
tannewt
by mtyeager on Fri Apr 10, 2020 2:51 pm
3.5.3
I'll upgrade to the latest and give that a try.
mtyeager
by mtyeager on Fri Apr 10, 2020 4:41 pm
Upgraded everything on the RPi.
Still showing Python versio 3.5.3
When I run rpi_ws281x Adafruit-circuitpython-neopixel, I get the same error as above.
I installed Adafruit-Blinka as part of the setup. It appeared to install without a problem.
Cound I have installed the latest version of Adafruit-Blinka, and the Adafruit-circuitpython-neopixel is looking for an earlier version?
I did this before, back in January, without a problem... NeoPixels were working fine. Didn't have this install issue. Has anything been changed recently?
mtyeager
by MakerMelissa on Mon Apr 13, 2020 6:17 pm
Can you try it without the sudo? You may have Blinka installed as a user package and adding sudo makes it try and install globally.
MakerMelissa
by mtyeager on Tue Apr 14, 2020 5:42 pm
YES! That was it. Thanks very much!
mtyeager
by MakerMelissa on Tue Apr 14, 2020 5:44 pm
Excellent! Glad to hear.
MakerMelissa
