Pass Pin Number as parameter
by scott_smith on Sat Apr 11, 2020 10:21 am
How can I pass a pin number as a paramater to digitalio.DigitalInOut()?
output = digitalio.DigitalInOut(board.D15)
works as expected
output_pin = D15
_output_pin = "board."+output_pin
output = digitalio.DigitalInOut(_output_pin)
#does not work
File "/home/pi/.local/lib/python3.7/site-packages/digitalio.py", line 86, in __init__
    self._pin = Pin(pin.id)
AttributeError: 'str' object has no attribute 'id'
Do I somehow need to convert this to an object? If so how?
scott_smith
Re: Pass Pin Number as parameter
by tannewt on Mon Apr 13, 2020 6:23 pm
I think you can use getattr:
getattr(board, output_pin)
getattr() will get the attribute on the first argument with the name given as the second argument.
tannewt
by scott_smith on Tue Apr 14, 2020 7:35 am
Thank you! I'll give it a try
scott_smith
