Pyportal JSON syntax error
by NavyJetFixer on Sun Apr 12, 2020 5:09 pm
I modified the NASA APOD example to use the NASA rover api in an attempt to retrieve rover photos to display on the Pyportal. I get an error that there is a syntax error. I this possibly because the file does not complete and not ended correctly.
Running this code:
import time
import board
from adafruit_pyportal import PyPortal
from secrets import secrets
key = secrets['nasakey']
# Set up where we'll be fetching data from
DATA_SOURCE = "https://api.nasa.gov/mars-photos/api/v1/rovers/curiosity/photos?sol=1000&page=1&api_key=" + key
# There's a few different places we look for data in the photo of the day
IMAGE_LOCATION = ["photos",0,"img_src"]
TITLE_LOCATION = ["photos",0,"camera","full_name"]
DATE_LOCATION = ["photos",0,"earth_date"]
# the current working directory (where this file is)
cwd = ("/"+__file__).rsplit('/', 1)[0]
pyportal = PyPortal(url=DATA_SOURCE,
                    json_path=(TITLE_LOCATION, DATE_LOCATION),
                    status_neopixel=board.NEOPIXEL,
                    default_bg=cwd+"/nasa_background.bmp",
                    text_font=cwd+"/fonts/Arial-12.bdf",
                    text_position=((5, 220), (5, 200)),
                    text_color=(0xFFFFFF, 0xFFFFFF),
                    text_maxlen=(50, 50), # cut off characters
                    image_json_path=IMAGE_LOCATION,
                    image_resize=(320, 240),
                    image_position=(0, 0),
                    debug = True)
while True:
    response = None
    try:
        response = pyportal.fetch()
        print("Response is", response)
    except RuntimeError as e:
        print("Some error occured, retrying! -", e)
    time.sleep(60*30)  # 30 minutes till next check
Here is the returned JSON and traceback:
{"photos":[{"id":102693,"sol":1000,"camera":{"id":20,"name":"FHAZ","rover_id":5,"full_name":"Front Hazard Avoidance Camera"},"img_src":"http://mars.jpl.nasa.gov/msl-raw-images/proj/msl/redops/ods/surface/sol/01000/opgs/edr/fcam/FLB_486265257EDR_F0481570FHAZ00323M_.JPG","earth_date":"2015-05-30","rover":{"id":5,"name":"Curiosity","landing_date":"2012-08-06","launch_date":"2011-11-26","status":"active","max_sol":2730,"max_date":"2020-04-11","total_photos":415214,"cameras":[{"name":"FHAZ","full_name":"Front Hazard Avoidance Camera"},{"name":"NAVCAM","full_name":"Navigation Camera"},{"name":"MAST","full_name":"Mast Camera"},{"name":"CHEMCAM","full_name":"Chemistry and Camera Complex"},{"name":"MAHLI","full_name":"Mars Hand Lens Imager"},{"name":"MARDI","full_name":"Mars Descent Imager"},{"name":"RHAZ","full_name":"Rear Hazard Avoidance Camera"}]}},{"id":102694,"sol":1000,"camera":{"id":20,"name":"FHAZ","rover_id":5,"full_name":"Front Hazard Avoidance Camera"},"img_src":"http://mars.jpl.nasa.gov/msl-raw-images/proj/msl/redops/ods/surface/sol/01000/opgs/edr/fcam/FRB_486265257EDR_F0481570FHAZ00323M_.JPG","earth_date":"2015-05-30","rover":{"id":5,"name":"Curiosity","landing_date":"2012-08-06","launch_date":"2011-11-26","status":"active","max_sol":2730,"max_date":"2020-04-11","total_photos":415214,"cameras":[{"name":"FHAZ","full_name":"Front Hazard Avoidance Camera"},{"name":"NAVCAM","full_name":"Navigation Camera"},{"name":"MAST","full_name":"Mast Camera"},{"name":"CHEMCAM","full_name":"Chemistry and Camera Complex"},{"name":"MAHLI","full_name":"Mars Hand Lens Imager"},{"name":"MARDI","full_name":"Mars Descent Imager"},{"name":"RHAZ","full_name":"Rear Hazard Avoidance Camera"}]}},{"id":102850,"sol":1000,"camera":{"id":21,"name":"RHAZ","rover_id":5,"full_name":"Rear Hazard Avoidance Camera"},"img_src":"http://mars.jpl.nasa.gov/msl-raw-images/proj/msl/redops/ods/surface/sol/01000/opgs/edr/rcam/RLB_486265291EDR_F0481570RHAZ00323M_.JPG","earth_date":"2015-05-30","rover":{"id":5,"name":"Curiosity","landing_date":"2012-08-06","launch_date":"2011-11-26","status":"active","max_sol":2730,"max_date":"2020-04-11","total_photos":415214,"cameras":[{"name":"FHAZ","full_name":"Front Hazard Avoidance Camera"},{"name":"NAVCAM","full_name":"Navigation Camera"},{"name":"MAST","full_name":"Mast Camera"},{"name":"CHEMCAM","full_name":"Chemistry and Camera Complex"},{"name":"MAHLI","full_name":"Mars Hand Lens Imager"},{"name":"MARDI","full_name":"Mars Descent Imager"},{"name":"RHAZ","full_name":"Rear Hazard Avoidance Camera"}]}},{"id":102851,"sol":1000,"camera":{"id":21,"name":"RHAZ","rover_id":5,"full_name":"Rear Hazard Avoidance Camera"},"img_src":"http://mars.jpl.nasa.gov/msl-raw-images/proj/msl/redops/ods/surface/sol/01000/opgs/edr/rcam/RRB_486265291EDR_F0481570RHAZ00323M_.JPG","earth_date":"2015-05-30","rover":{"id":5,"name":"Curiosity","landing_date":"2012-08-06","launch_date":"2011-11-26","status":"active","max_sol":2730,"max_date":"2020-04-11","total_photos":415214,"cameras":[{"name":"FHAZ","full_name":"Front Hazard Avoidance Camera"},{"name":"NAVCAM","full_name":"Navigation Camera"},{"name":"MAST","full_name":"Mast Camera"},{"name":"CHEMCAM","full_name":"Chemistry and Camera Complex"},{"name":"MAHLI","full_name":"Mars Hand Lens Imager"},{"name":"MARDI","full_name":"Mars Descent Imager"},{"name":"RHAZ","full_name":"Rear Hazard Avoidance Camera"}]}},{"id":424905,"sol":1000,"camera":{"id":22,"name":"MAST","rover_id":5,"full_name":"Mast Camera"},"img_src":"http://mars.jpl.nasa.gov/msl-raw-images/msss/01000/mcam/1000MR0044631300503690E01_DXXX.jpg","earth_date":"2015-05-30","rover":{"id":5,"name":"Curiosity","landing_date":"2012-08-06","launch_date":"2011-11-26","status":"active","max_sol":2730,"max_date":"2020-04-11","total_photos":415214,"cameras":[{"name":"FHAZ","full_name":"Front Hazard Avoidance Camera"},{"name":"NAVCAM","full_name":"Navigation Camera"},{"name":"MAST","full_name":"Mast Camera"},{"name":"CHEMCAM","full_name":"Chemistry and Camera Complex"},{"name":"MAHLI","full_name":"Mars Hand Lens Imager"},{"name":"MARDI","full_name":"Mars Descent Imager"},{"name":"RHAZ","full_name":"Rear Hazard Avoidance Camera"}]}},{"id":424906,"sol":1000,"camera":{"id":22,"name":"MAST","rover_id":5,"full_name":"Mast Camera"},"img_src":"http://mars.jpl.nasa.gov/msl-raw-images/msss/01000/mcam/1000ML0044631300305227E03_DXXX.jpg","earth_date":"2015-05-30","rover":{"id":5,"name":"Curiosity","landing_date":"2012-08-06","launch_date":"2011-11-26","status":"active","max_sol":2730,"max_date":"2020-04-11","total_photos":415214,"cameras":[{"name":"FHAZ","full_name":"Front Hazard Avoidance Camera"},{"name":"NAVCAM","full_name":"Navigation Camera"},{"name":"MAST","full_name":"Mast Camera"},{"name":"CHEMCAM","full_name":"Chemistry and Camera Complex"},{"name":"MAHLI","full_name":"Mars Hand Lens Imager"},{"name":"MARDI","full_name":"Mars Descent Imager"},{"name":"RHAZ","full_name":"Rear Hazard Avoidance Camera"}]}},{"id":424907,"sol":1000,"camera":{"id":22,"name":"MAST","rover_id":5,"full_name":"Mast Camera"},"img_src":"http://mars.jpl.nasa.gov/msl-raw-images/msss/01000/mcam/1000MR0044631290503689E01_DXXX.jpg","earth_date":"2015-05-30","rover":{"id":5,"name":"Curiosity","landing_date":"2012-08-06","launch_date":"2011-11-26","status":"active","max_sol":2730,"max_date":"2020-04-11","total_photos":415214,"cameras":[{"name":"FHAZ","full_name":"Front Hazard Avoidance Camera"},{"name":"NAVCAM","full_name":"Navigation Camera"},{"name":"MAST","full_name":"Mast Camera"},{"name":"CHEMCAM","full_name":"Chemistry and Camera Complex"},{"name":"MAHLI","full_name":"Mars Hand Lens Imager"},{"name":"MARDI","full_name":"Mars Descent Imager"},{"name":"RHAZ","full_name":"Rear Hazard Avoidance Camera"}]}},{"id":424908,"sol":1000,"camera":{"id":22,"name":"MAST","rover_id":5,"full_name":"Mast Camera"},"img_src":"http://mars.jpl.nasa.gov/msl-raw-images/msss/01000/mcam/1000ML0044631290305226E03_DXXX.jpg","earth_date":"2015-05-30","rover":{"id":5,"name":"Curiosity","landing_date":"2012-08-06","launch_date":"2011-11-26","status":"active","max_sol":2730,"max_date":"2020-04-11","total_photos":415214,"cameras":[{"name":"FHAZ","full_name":"Front Hazard Avoidance Camera"},{"name":"NAVCAM","full_name":"Navigation Camera"},{"name":"MAST","full_name":"Mast Camera"},{"name":"CHEMCAM","full_name":"Chemistry and Camera Complex"},{"name":"MAHLI","full_name":"Mars Hand Lens Imager"},{"name":"MARDI","full_name":"Mars Descent Imager"},{"name":"RHAZ","full_name":"Rear Hazard Avoidance Camera"}]}},{"id":424909,"sol":1000,"camera":{"id":22,"name":"MAST","rover_id":5,"full_name":"Mast Camera"},"img_src":"http://mars.jpl.nasa.gov/msl-raw-images/msss/01000/mcam/1000MR0044631280503688E0B_DXXX.jpg","earth_date":"2015-05-30","rover":{"id":5,"name":"Curiosity","landing_date":"2012-08-06","launch_date":"2011-11-26","status":"active","max_sol":2730,"max_date":"2020-04-11","total_photos":415214,"cameras":[{"name":"FHAZ","full_name":"Front Hazard Avoidance Camera"},{"name":"NAVCAM","full_name":"Navigation Camera"},{"name":"MAST","full_name":"Mast Camera"},{"name":"CHEMCAM","full_name":"Chemistry and Camera Complex"},{"name":"MAHLI","full_name":"Mars Hand Lens Imager"},{"name":"MARDI","full_name":"Mars Descent Imager"},{"name":"RHAZ","full_name":"Rear Hazard Avo
Couldn't parse json: {"photos":[{"id":102693,"sol":1000,"camera":{"id":20,"name":"FHAZ","rover_id":5,"full_name":"Front Hazard Avoidance Camera"},"img_src":"http://mars.jpl.nasa.gov/msl-raw-images/proj/msl/redops/ods/surface/sol/01000/opgs/edr/fcam/FLB_486265257EDR_F0481570FHAZ00323M_.JPG","earth_date":"2015-05-30","rover":{"id":5,"name":"Curiosity","landing_date":"2012-08-06","launch_date":"2011-11-26","status":"active","max_sol":2730,"max_date":"2020-04-11","total_photos":415214,"cameras":[{"name":"FHAZ","full_name":"Front Hazard Avoidance Camera"},{"name":"NAVCAM","full_name":"Navigation Camera"},{"name":"MAST","full_name":"Mast Camera"},{"name":"CHEMCAM","full_name":"Chemistry and Camera Complex"},{"name":"MAHLI","full_name":"Mars Hand Lens Imager"},{"name":"MARDI","full_name":"Mars Descent Imager"},{"name":"RHAZ","full_name":"Rear Hazard Avoidance Camera"}]}},{"id":102694,"sol":1000,"camera":{"id":20,"name":"FHAZ","rover_id":5,"full_name":"Front Hazard Avoidance Camera"},"img_src":"http://mars.jpl.nasa.gov/msl-raw-images/proj/msl/redops/ods/surface/sol/01000/opgs/edr/fcam/FRB_486265257EDR_F0481570FHAZ00323M_.JPG","earth_date":"2015-05-30","rover":{"id":5,"name":"Curiosity","landing_date":"2012-08-06","launch_date":"2011-11-26","status":"active","max_sol":2730,"max_date":"2020-04-11","total_photos":415214,"cameras":[{"name":"FHAZ","full_name":"Front Hazard Avoidance Camera"},{"name":"NAVCAM","full_name":"Navigation Camera"},{"name":"MAST","full_name":"Mast Camera"},{"name":"CHEMCAM","full_name":"Chemistry and Camera Complex"},{"name":"MAHLI","full_name":"Mars Hand Lens Imager"},{"name":"MARDI","full_name":"Mars Descent Imager"},{"name":"RHAZ","full_name":"Rear Hazard Avoidance Camera"}]}},{"id":102850,"sol":1000,"camera":{"id":21,"name":"RHAZ","rover_id":5,"full_name":"Rear Hazard Avoidance Camera"},"img_src":"http://mars.jpl.nasa.gov/msl-raw-images/proj/msl/redops/ods/surface/sol/01000/opgs/edr/rcam/RLB_486265291EDR_F0481570RHAZ00323M_.JPG","earth_date":"2015-05-30","rover":{"id":5,"name":"Curiosity","landing_date":"2012-08-06","launch_date":"2011-11-26","status":"active","max_sol":2730,"max_date":"2020-04-11","total_photos":415214,"cameras":[{"name":"FHAZ","full_name":"Front Hazard Avoidance Camera"},{"name":"NAVCAM","full_name":"Navigation Camera"},{"name":"MAST","full_name":"Mast Camera"},{"name":"CHEMCAM","full_name":"Chemistry and Camera Complex"},{"name":"MAHLI","full_name":"Mars Hand Lens Imager"},{"name":"MARDI","full_name":"Mars Descent Imager"},{"name":"RHAZ","full_name":"Rear Hazard Avoidance Camera"}]}},{"id":102851,"sol":1000,"camera":{"id":21,"name":"RHAZ","rover_id":5,"full_name":"Rear Hazard Avoidance Camera"},"img_src":"http://mars.jpl.nasa.gov/msl-raw-images/proj/msl/redops/ods/surface/sol/01000/opgs/edr/rcam/RRB_486265291EDR_F0481570RHAZ00323M_.JPG","earth_date":"2015-05-30","rover":{"id":5,"name":"Curiosity","landing_date":"2012-08-06","launch_date":"2011-11-26","status":"active","max_sol":2730,"max_date":"2020-04-11","total_photos":415214,"cameras":[{"name":"FHAZ","full_name":"Front Hazard Avoidance Camera"},{"name":"NAVCAM","full_name":"Navigation Camera"},{"name":"MAST","full_name":"Mast Camera"},{"name":"CHEMCAM","full_name":"Chemistry and Camera Complex"},{"name":"MAHLI","full_name":"Mars Hand Lens Imager"},{"name":"MARDI","full_name":"Mars Descent Imager"},{"name":"RHAZ","full_name":"Rear Hazard Avoidance Camera"}]}},{"id":424905,"sol":1000,"camera":{"id":22,"name":"MAST","rover_id":5,"full_name":"Mast Camera"},"img_src":"http://mars.jpl.nasa.gov/msl-raw-images/msss/01000/mcam/1000MR0044631300503690E01_DXXX.jpg","earth_date":"2015-05-30","rover":{"id":5,"name":"Curiosity","landing_date":"2012-08-06","launch_date":"2011-11-26","status":"active","max_sol":2730,"max_date":"2020-04-11","total_photos":415214,"cameras":[{"name":"FHAZ","full_name":"Front Hazard Avoidance Camera"},{"name":"NAVCAM","full_name":"Navigation Camera"},{"name":"MAST","full_name":"Mast Camera"},{"name":"CHEMCAM","full_name":"Chemistry and Camera Complex"},{"name":"MAHLI","full_name":"Mars Hand Lens Imager"},{"name":"MARDI","full_name":"Mars Descent Imager"},{"name":"RHAZ","full_name":"Rear Hazard Avoidance Camera"}]}},{"id":424906,"sol":1000,"camera":{"id":22,"name":"MAST","rover_id":5,"full_name":"Mast Camera"},"img_src":"http://mars.jpl.nasa.gov/msl-raw-images/msss/01000/mcam/1000ML0044631300305227E03_DXXX.jpg","earth_date":"2015-05-30","rover":{"id":5,"name":"Curiosity","landing_date":"2012-08-06","launch_date":"2011-11-26","status":"active","max_sol":2730,"max_date":"2020-04-11","total_photos":415214,"cameras":[{"name":"FHAZ","full_name":"Front Hazard Avoidance Camera"},{"name":"NAVCAM","full_name":"Navigation Camera"},{"name":"MAST","full_name":"Mast Camera"},{"name":"CHEMCAM","full_name":"Chemistry and Camera Complex"},{"name":"MAHLI","full_name":"Mars Hand Lens Imager"},{"name":"MARDI","full_name":"Mars Descent Imager"},{"name":"RHAZ","full_name":"Rear Hazard Avoidance Camera"}]}},{"id":424907,"sol":1000,"camera":{"id":22,"name":"MAST","rover_id":5,"full_name":"Mast Camera"},"img_src":"http://mars.jpl.nasa.gov/msl-raw-images/msss/01000/mcam/1000MR0044631290503689E01_DXXX.jpg","earth_date":"2015-05-30","rover":{"id":5,"name":"Curiosity","landing_date":"2012-08-06","launch_date":"2011-11-26","status":"active","max_sol":2730,"max_date":"2020-04-11","total_photos":415214,"cameras":[{"name":"FHAZ","full_name":"Front Hazard Avoidance Camera"},{"name":"NAVCAM","full_name":"Navigation Camera"},{"name":"MAST","full_name":"Mast Camera"},{"name":"CHEMCAM","full_name":"Chemistry and Camera Complex"},{"name":"MAHLI","full_name":"Mars Hand Lens Imager"},{"name":"MARDI","full_name":"Mars Descent Imager"},{"name":"RHAZ","full_name":"Rear Hazard Avoidance Camera"}]}},{"id":424908,"sol":1000,"camera":{"id":22,"name":"MAST","rover_id":5,"full_name":"Mast Camera"},"img_src":"http://mars.jpl.nasa.gov/msl-raw-images/msss/01000/mcam/1000ML0044631290305226E03_DXXX.jpg","earth_date":"2015-05-30","rover":{"id":5,"name":"Curiosity","landing_date":"2012-08-06","launch_date":"2011-11-26","status":"active","max_sol":2730,"max_date":"2020-04-11","total_photos":415214,"cameras":[{"name":"FHAZ","full_name":"Front Hazard Avoidance Camera"},{"name":"NAVCAM","full_name":"Navigation Camera"},{"name":"MAST","full_name":"Mast Camera"},{"name":"CHEMCAM","full_name":"Chemistry and Camera Complex"},{"name":"MAHLI","full_name":"Mars Hand Lens Imager"},{"name":"MARDI","full_name":"Mars Descent Imager"},{"name":"RHAZ","full_name":"Rear Hazard Avoidance Camera"}]}},{"id":424909,"sol":1000,"camera":{"id":22,"name":"MAST","rover_id":5,"full_name":"Mast Camera"},"img_src":"http://mars.jpl.nasa.gov/msl-raw-images/msss/01000/mcam/1000MR0044631280503688E0B_DXXX.jpg","earth_date":"2015-05-30","rover":{"id":5,"name":"Curiosity","landing_date":"2012-08-06","launch_date":"2011-11-26","status":"active","max_sol":2730,"max_date":"2020-04-11","total_photos":415214,"cameras":[{"name":"FHAZ","full_name":"Front Hazard Avoidance Camera"},{"name":"NAVCAM","full_name":"Navigation Camera"},{"name":"MAST","full_name":"Mast Camera"},{"name":"CHEMCAM","full_name":"Chemistry and Camera Complex"},{"name":"MAHLI","full_name":"Mars Hand Lens Imager"},{"name":"MARDI","full_name":"Mars Descent Imager"},{"name":"RHAZ","full_name":"Rear Hazard Avo
File "code.py", line 35, in <module>
File "code.py", line 32, in <module>
File "adafruit_pyportal.py", line 897, in fetch
File "adafruit_pyportal.py", line 893, in fetch
File "adafruit_requests.py", line 134, in json
ValueError: syntax error in JSON
NavyJetFixer
Re: Pyportal JSON syntax error
by dastels on Sun Apr 12, 2020 6:53 pm
If the file ends prematurely, it should definitely cause a JSON error. It's not valid JSON. Any idea why that's happening?
dastels
by NavyJetFixer on Mon Apr 13, 2020 2:05 pm
No, maybe my slow internet connection and a timeout occurs and the file is truncated without ending correctly.
NavyJetFixer
by dastels on Mon Apr 13, 2020 2:55 pm
Possibly, or maybe a buffer limitation?
dastels
by NavyJetFixer on Mon Apr 13, 2020 6:29 pm
Don't think that I have control of the buffer size using the pyportal.fetch(). Is there another way to get the JSON file and then extract what I need and pass that to the pyportal.
NavyJetFixer
by dastels on Mon Apr 13, 2020 10:33 pm
Yes, the buffer is managed by the request code.
You could just not use the PyPortal class. You would have to do everything yourself, but you'd have complete control.
dastels
by NavyJetFixer on Wed Apr 15, 2020 4:05 pm
I have tried doing that using the Internet Connect! sample from the Pyportal guides. It uses a socket and adafruit_requests.py. When a get a smaller JSON file it works just fine. But larger file from the rover API seems like it is to big. I have limited it to the first 25 items, but still get an error. I have used a browser to retrieve the file and several online JSON interpreters say the file is a valid JSON file. As far a I can tell the GET request is to big to be read completely.
NavyJetFixer
by dastels on Wed Apr 15, 2020 9:48 pm
Very well might be. The PyPortal is a small scale system. Is it possible to get individual items, extracting what you need from each?
dastels
