feather m4 express i2c as digital out
by jwillner1958 on Mon Apr 13, 2020 9:52 am
Hello together,
I would like to use the i2c-interface as a digital out.
Is that possible?
Isn't working for me yet...
led1 = digitalio.DigitalInOut(board.D22)
led2 = digitalio.DigitalInOut(board.D22)
led1.direction = digitalio.Direction.OUTPUT
led2.direction = digitalio.Direction.OUTPUT
br
jwillner1958
Re: feather m4 express i2c as digital out
by jerryn on Mon Apr 13, 2020 10:02 am
there is no board.D22 defined for the feather M4 express (you are using it for both leds ?? )
have you tried
led1 = digitalio.DigitalInOut(board.SDA)
led2 = digitalio.DigitalInOut(board.SCL)
edited to add -- Just tested on a feather m4 express and it works for me.
jerryn
by jwillner1958 on Mon Apr 13, 2020 2:32 pm
thank you very much, that solved the problem.
I am a newby, was searching for the info, where this things are defined. but was not successful.
can you give me a hint, where to study this...
br Joachim
jwillner1958
by jerryn on Mon Apr 13, 2020 4:20 pm
It can be confusing - I assume that the references to #21 and #22 in the Guide "pinouts" section are for Arduino.
For CircuitPython, every board has a "pins.c" file that defines the pin mapping.
for the Feather M4 Express it is here https://github.com/adafruit/circuitpython/blob/master/ports/atmel-samd/boards/feather_m4_express/pins.c#L37
I hope that helps. You can also ask questions like this in the #help-with-circuitpython channel on the discord server at https://adafru.it/discord
jerryn
