Rotary encoder support on RPI with Blinka
by cache_return on Tue Apr 14, 2020 9:40 am
I have read that CircuitPython supports rotary encoders via rotaryio. I was trying to attach two of these via GPIO on a raspberry Pi and use adafruit-blinka to run them, but I can't find the function. Does it exist?
cache_return
Re: Rotary encoder support on RPI with Blinka
by tannewt on Tue Apr 14, 2020 4:51 pm
I don't believe Blinka support rotaryio because it is implemented at a low level that may be challenging within Linux.
tannewt
by cache_return on Tue Apr 14, 2020 8:12 pm
I don't believe it's supported either. If this is true, the question is what do I do?
cache_return
by tannewt on Wed Apr 15, 2020 4:13 pm
What are you trying to use the rotary encoders for?
tannewt
by cache_return on Thu Apr 16, 2020 1:05 pm
Encoder 1: Volume control (via mpc volume+/-1) and Play/Pause (via mpc toggle).
Encoder 2: Scroll up/down (with up arrow and down arrow) and Enter key.
I am finding a lot of examples where people have attempted this, but I was hoping blinka would be less buggy than the ones I tried.
cache_return
by tannewt on Fri Apr 17, 2020 1:26 pm
I'd recommend picking up a cheap external CircuitPython board like an ItsyBitsy M4. It can translate the rotary encoders to USB HID which can control the Raspberry Pi. This is a good guide for it: https://learn.adafruit.com/rotary-encoder/circuitpython
tannewt
by cache_return on Tue Apr 21, 2020 9:42 am
Here is how I solved the problem. It's not perfect (sometimes the scrolling jitters a little), but it's pretty good.
import os
import signal
import subprocess
import sys
import threading
class RotaryEncoder:
  A class to decode mechanical rotary encoder pulses.
  Ported to RPi.GPIO from the pigpio sample here:
  http://abyz.co.uk/rpi/pigpio/examples.html
  def __init__(self, gpioA, gpioB, callback=None, buttonPin=None, buttonCallback=None):
    Instantiate the class. Takes three arguments: the two pin numbers to
    which the rotary encoder is connected, plus a callback to run when the
    switch is turned.
    The callback receives one argument: a `delta` that will be either 1 or -1.
    One of them means that the dial is being turned to the right; the other
    means that the dial is being turned to the left. I'll be damned if I know
    yet which one is which.
    self.lastGpio = None
    self.gpioA    = gpioA
    self.gpioB    = gpioB
    self.callback = callback
    self.gpioButton     = buttonPin
    self.buttonCallback = buttonCallback
    self.levA = 0
    self.levB = 0
    GPIO.setmode(GPIO.BCM)
    GPIO.setup(self.gpioA, GPIO.IN, pull_up_down=GPIO.PUD_UP)
    GPIO.setup(self.gpioB, GPIO.IN, pull_up_down=GPIO.PUD_UP)
    GPIO.add_event_detect(self.gpioA, GPIO.BOTH, self._callback)
    GPIO.add_event_detect(self.gpioB, GPIO.BOTH, self._callback)
    if self.gpioButton:
      GPIO.setup(self.gpioButton, GPIO.IN, pull_up_down=GPIO.PUD_UP)
      GPIO.add_event_detect(self.gpioButton, GPIO.FALLING, self._buttonCallback, bouncetime=500)
  def destroy(self):
    GPIO.remove_event_detect(self.gpioA)
    GPIO.remove_event_detect(self.gpioB)
    GPIO.cleanup()
  def _buttonCallback(self, channel):
    self.buttonCallback(GPIO.input(channel))
  def _callback(self, channel):
    level = GPIO.input(channel)
    if channel == self.gpioA:
      self.levA = level
    else:
      self.levB = level
    # Debounce.
    if channel == self.lastGpio:
      return
    # When both inputs are at 1, we'll fire a callback. If A was the most
    # recent pin set high, it'll be forward, and if B was the most recent pin
    # set high, it'll be reverse.
    self.lastGpio = channel
    if channel == self.gpioA and level == 1:
      if self.levB == 1:
        self.callback(1)
    elif channel == self.gpioB and level == 1:
      if self.levA == 1:
        self.callback(-1)
cache_return
