TouchScreen on Pyportal Titano
by TxPvCoach on Wed Apr 15, 2020 8:35 pm
When i run this to test my touchscreen functionality.It just prints tuple after tuple and only the z-pressure changes. Do i have a bad touchscreen ? Should i only get output when touchscreen is touched? Any ideas or further tests to carry out
import board
import adafruit_touchscreen
touchscreen = adafruit_touchscreen.Touchscreen(
    board.TOUCH_XL,
    board.TOUCH_XR,
    board.TOUCH_YD,
    board.TOUCH_YU,
    # calibration=((9000, 59000), (8000, 57000)),
    # resistance=None
    size=(board.DISPLAY.width, board.DISPLAY.height),
while True:
    point_being_touched = touchscreen.touch_point
    if point_being_touched:
        print(
            'Touch at (%s, %s) Pressure: %s' %
            (point_being_touched[0],
             point_being_touched[1],
             point_being_touched[2]),
touchscreen.py .jpg (168.53 KiB) Viewed 30 times
TxPvCoach
Re: TouchScreen on Pyportal Titano
by TxPvCoach on Thu Apr 16, 2020 6:36 pm
Reseat The Cable for Display and Touch Screen
Pull the two black tabs at the ends of the connector toward the slot to release the cable, pull the cable all the way out of the connector, then put it back in making sure it goes all the way in, all the way across. Then push the black tabs back to re-clamp the cable.
TxPvCoach
