mpy-cross build error on MacOS
by Tavda3172 on Fri Apr 17, 2020 5:34 pm
I am trying to convert some .py files to .mpy in order to reduce their size to fit on my Itsy Bitsy M0 Express. I have followed along with the instructions here:
https://learn.adafruit.com/building-circuitpython/macos
and here:
https://learn.adafruit.com/building-circuitpython/build-circuitpython
The problem is when I try to build mpy-cross I get the following error:
"make: msgfmt: No such file or directory
make: *** [build/genhdr/en_US.mo] Error 1
I am a little out of my element with all of this and using the command line, but if I try using MicroPython's mpy-cross (https://github.com/micropython/micropython/tree/master/mpy-cross) it works just fine. However, it seems that those .mpy files are not compatible with the latest version of CircuitPython.
I'm not sure if this is a bug or if I am doing something wrong but any help would be greatly appreciated. This seems like an important piece of using CircuiPython effectively so I hope there is an easy solution. Thank you in advance,
Kevin
Tavda3172
Re: mpy-cross build error on MacOS
by FutureTechLab on Fri Apr 17, 2020 7:42 pm
I too am experiencing this issue and would like to find a solution.
FutureTechLab
by tannewt on Fri Apr 17, 2020 7:46 pm
Hi! Please make sure gettext is installed. It includes msgfmt which seems to be what you are missing. This is a CircuitPython-only thing because we support translated error messages and MicroPython doesn't.
tannewt
by Tavda3172 on Fri Apr 17, 2020 8:09 pm
Hi, thanks for the quick response! Ok, so I just tried to add gettext using:
brew upgrade gettext
and I got "Warning: gettext 0.20.2 already installed". Could it be in the wrong place? How do I go about checking for it?
Tavda3172
by Tavda3172 on Fri Apr 17, 2020 8:33 pm
Ok, I've confirmed that I have gettext installed and I still get the "make: msgfmt: No such file or directory
make: *** [build/genhdr/en_US.mo] Error 1"
error.
Tavda3172
by FutureTechLab on Fri Apr 17, 2020 8:55 pm
I have resolved the issue by doing the following
$ brew install gettext
$ sudo nano /etc/paths
add the following path
/usr/local/Cellar/gettext/0.20.2/bin
ctrl + X, y, Return
Restart terminal
cd to the mpy-cross folder
make
FutureTechLab
by tannewt on Mon Apr 20, 2020 12:48 pm
Glad you got it going! Thanks for posting the solution.
tannewt
by Tavda3172 on Mon Apr 20, 2020 8:35 pm
That worked! Woohoo:) Thank you for figuring that out. Now to get that code to fit... :)
Tavda3172
