PyPortal HCSR04 3 Wires
by kwalkerk on Sat Apr 18, 2020 2:14 pm
I'm trying to connect an HCSR04 distance sensor to my PyPortal.
I would like to use the 3 wire approach where the trigger and echo pins are tied together. This works fine on Arduino's
Here is the relevant code:
import adafruit_hcsr04
sonar = adafruit_hcsr04.HCSR04(trigger_pin=board.D3, echo_pin=board.D3)
But I get the following error: ValueError: D3 in use
Is this not possible on the PyPortal or am I missing something?
Thanks.
kwalkerk
Re: PyPortal HCSR04 3 Wires
by tannewt on Mon Apr 20, 2020 12:52 pm
I don't think it's possible because we don't want to assume the pin can be changed to an input fast enough after the trigger.
tannewt
by kwalkerk on Mon Apr 20, 2020 12:56 pm
Thanks. That's what I thought. I'm getting it to work by using 4 wires and all three pins on D3 and just the data pin on D4. Since I'm not connecting anything else to D4 this works fine.
kwalkerk
cron
