Black Lives Matter - Action and Equality. ... Adafruit is part of the Stop Hate for Profit campaign. Adafruit is open and shipping.
Incorrect analog readings on Pyportal D3 and D4 connectors
by Jeeg76 on Tue Apr 21, 2020 3:43 pm
Hello everyone. Forgive my English and my inexperience, I am a noob whit python and microcontrollers.
I have a Pyportal to which I have connected several analog sensors, like moisture sensor and water level sensor (3 pin, + - sig).
I connected them with a jst cable, and I have coded this example:
import time
import board
from analogio import AnalogIn
analog_in = AnalogIn(board.D3)
while True:
    print(analog_in.value)
    time.sleep(1)
The problem is that: I always have a high reading that never changes (64480) or changes very little, even if, for example, I put the moisture sensor in water. On an esp8266 the sensor works perfectly. Pyportal works well, I have uploaded complex examples such as the weather station and they work well ... This happens on both D3 and D4 .....
Thanks for your help
Jeeg76
Re: Incorrect analog readings on Pyportal D3 and D4 connecto
by dastels on Tue Apr 21, 2020 4:25 pm
I would start by examining the soldered connections.
Ensure that the JST connector is firmly seated in the socket.
dastels
by Jeeg76 on Wed Apr 22, 2020 7:54 am
I rechecked the connections, the jst connectors seem to be inserted correctly and work properly, tested on an esp8266 the sensors work using just that cable. I also noticed that if I read, with nothing attached, a value is still returned. It's normal?
I tried to test the pyportal temperature sensor and it works and the led also works regularly. I physically checked the card and it seems to have no defects, as far as I can understand, I'm inexperienced :)
i use this cable https://www.adafruit.com/product/4046
and this https://shop.pimoroni.com/products/3-pi ... 1-housings
I will try to test the readings or writings digitally
Jeeg76
by adafruit2 on Wed Apr 22, 2020 11:46 am
try changing the onboard JST-voltage jumper from 5V to 3V
adafruit2
Site Admin
by Jeeg76 on Wed Apr 22, 2020 2:56 pm
How i can make that? I need to cut the trace on 5v -3v on i2c connector?
thx
Jeeg76
by dastels on Wed Apr 22, 2020 3:19 pm
If you look next to the I2C connector you will see 3 pads, labelled 5, V, and 3. There is a small trace between 5 and V. Carefully cut that and connect V and 3. A blob of solder will do the job.
dastels
