Black Lives Matter - Action and Equality. ... Adafruit is part of the Stop Hate for Profit campaign. Adafruit is open and shipping.
Pyportal CircuitPython MiniMQTT problems and errors
by Jeeg76 on Wed Apr 22, 2020 9:14 am
i am trying to execute the sample code of this guide https://learn.adafruit.com/mqtt-in-circuitpython, i have updated the libraries and circuitpython is the latest stable version (5.2.0).
I have the following problem: the example with adafruit broker works perfectly. The example where I use an internal broker (mosquito on home assistant, which works great with other clients) doesn't work at all. In particular, it gives me the error: Can't convert 'str' object to bytes implicitly. This happens in all the example files that I found for library.
this is like my code:
.......... # Connect to WiFi
print("Connecting to WiFi...")
wifi.connect()
print("Connected!") #[b]here work great and the pyportal connect[/b]
# Initialize MQTT interface with the esp interface
MQTT.set_socket(socket, esp)
# Set up a MiniMQTT Client
client = MQTT.MQTT(
    broker=secrets["broker"],
for the broker, in the secrets file i have add
broker : "MY_IP" --- like 192.168.ecc
for the test i dont have user and password
the broker is up and running.
it seems to be related to the interpretation of the IP address, but I am a complete beginner and I can't solve ....
If i use adafruit io , it works perfectly
Thanks for your help
Jeeg76
Re: Pyportal CircuitPython MiniMQTT problems and errors
by Jeeg76 on Thu Apr 23, 2020 11:52 am
[SOLVED] I need to write broker's IP in this way broker = "http://192.168.ecc.ecc) and work!
Jeeg76
cron
