Placement of displayio elements for efficient updates?
by kevinjwalters on Wed Apr 29, 2020 10:07 am
Can the geographical placement of objects on the screen using displayio library affect performance for applications which want to update the screen frequently? E.g. for data updating at 10-100Hz is there a difference between:
BIG TEXT SHOWING DYNAMIC DATA
GRAPH SHOWING SAME DATA
STATIC TEXT
and the re-ordered
STATIC TEXT
I'm wondering if the second option causes larger area writes to the screen from possible coalescing of the areas updated? Also, is it important to avoid even 1 pixel overlaps between static and dynamic objects for similar reasons?
kevinjwalters
Re: Placement of displayio elements for efficient updates?
by tannewt on Wed Apr 29, 2020 11:36 am
It depends on how your text is implemented. Are you using one TileGrid for everything or a Label which uses a TileGrid per character?
Note that the display is limited to 60Hz updates by default. You can change this rate by switching to manual refresh and providing a target frames per second to refresh.
tannewt
