feather_nRF52840_express bootloader
by johncblacker on Thu Apr 30, 2020 10:02 am
I have questions regarding the .uf2 bootloader delivered on my board (just a few days ago). I placed the device into bootloader mode and looked at the "text" file. It says:
UF2 Bootloader 0.2.6 lib/nrfx (v1.1.0-1-g096e770) lib/tinyusb (legacy-525-ga1c59649) s140 6.1.1
Model: Adafruit Feather nRF52840 Express
Board-ID: NRF52-Bluefruit-v0
Bootloader: s140 6.1.1
Date: Dec 21 2018
I'm wondering whether the UF2 Bootloader 0.2.6...can be updated to a later version easily. I do have j-link and seeger software, etc. but I'm wondering if a drag and drop will work just like with the other "feather...express" boards delivered today by adafruit?
johncblacker
Re: feather_nRF52840_express bootloader
by johncblacker on Thu Apr 30, 2020 10:03 am
I was able to drag/drop circuitpython onto the "drive" and get 5.x running on it.
johncblacker
by johncblacker on Thu Apr 30, 2020 10:24 am
Note: when I drop a adafruit pre-built cp firmware uf2 file on the drive when in boot mode, it opens a dialog box indicating an error with "RETRY/SKIP/CANCEL" and if I select retry, it does complete, but the drive doesn't look like a normal cp drive - lib isn't there and it doesn't show as a cp drive; but, cp is there and if I open the usb port with mu-editor, it appears normal and the modules are there. I've looked at the file system and all that's there is the '/' file system. I would think I'd be seeing the '/flash' file system? So, I don't know what's going on...
johncblacker
by johncblacker on Thu Apr 30, 2020 10:31 am
Another oddity is that the .uf2 firmware file is showing on the usb drive, as well!
johncblacker
by tannewt on Thu Apr 30, 2020 1:49 pm
johncblacker wrote:Note: when I drop a adafruit pre-built cp firmware uf2 file on the drive when in boot mode, it opens a dialog box indicating an error with "RETRY/SKIP/CANCEL" and if I select retry, it does complete, but the drive doesn't look like a normal cp drive - lib isn't there and it doesn't show as a cp drive; but, cp is there and if I open the usb port with mu-editor, it appears normal and the modules are there. I've looked at the file system and all that's there is the '/' file system. I would think I'd be seeing the '/flash' file system? So, I don't know what's going on...
I believe early versions of the nRF bootloader disconnect a bit too early to make the host OS happy. It only does it when it has all the info it needs though so you can ignore the error. I don't believe we have a uf2 updater for nRF like we do for atmel-samd. Thach is creating one though.
johncblacker wrote:Another oddity is that the .uf2 firmware file is showing on the usb drive, as well!
I think this is because the retry wrote it to CIRCUITPY and not the bootloader FS because the bootloader disconnects and resets once it has the whole uf2 file.
tannewt
by johncblacker on Thu Apr 30, 2020 2:02 pm
Thanks. I did an erase_filesystem, then dropped cp and was ok.
johncblacker
