Black Lives Matter - Action and Equality.
MAX31856 on Raspberry pi 4 : Temperature = 0,0
by Monsieur_x on Fri May 01, 2020 10:46 am
Hello everyone!
As part of an internship project, I have to use a MAX31856 module from adafruit. This module is a CAN amplifier
which has the ability to read any type of thermocouple.
To begin I try to perform this operation on a thermocouple. However, I am not a regular user of the
raspberry Pi.
I own the model Raspberry Pi 4+.
I followed the following tutorial https://cdn-learn.adafruit.com/download ... lifier.pdf
by doing the steps on the raspberry part.
So I did download the latest version of the bundle. I then recovered the necessary modules either:
adafruit_max31856.mpy
adafruit_bus_device
I transferred both of those files to /lib.
And on the balance sheet when I run the simple.py test I get 0.0 as you can see on the first figure.
Then I run a defect detection program given in the downloaded library and I get the second picture.
Finally I checked the connections several times, I bought a new part thinking that maybe I had made a short circuit but still nothing.
Thank you for your help!
Monsieur_x
Re: MAX31856 on Raspberry pi 4 : Temperature = 0,0
by adafruit_support_carter on Fri May 01, 2020 7:19 pm
You should install the libraries using pip:
https://learn.adafruit.com/adafruit-max ... ibrary-5-9
Do you have a thermocouple actually attached to the MAX31856?
by Monsieur_x on Sat May 02, 2020 10:51 am
Yes i used sudo pip3 install adafruit-circuitpython-max31856
Of course, i've got a thermocouple attached on the MAX31856
Monsieur_x
by Monsieur_x on Sat May 02, 2020 11:45 am
Maybe this will help you. I used the debug.
Monsieur_x
by Monsieur_x on Mon May 04, 2020 1:39 pm
Hello ! i send a picture with the electrical mounting
(Thermocouple is'nt connected on the white breadboard
Thx
Monsieur_x
by adafruit_support_carter on Mon May 04, 2020 1:47 pm
Can you post another photo showing the soldering on the breakout headers.
by Monsieur_x on Mon May 04, 2020 2:56 pm
i use this
Monsieur_x
by adafruit_support_carter on Mon May 04, 2020 7:22 pm
Are they not soldered on? If not, you'll need to do that to be able to communicate with the breakout.
https://learn.adafruit.com/adafruit-gui ... aq-3028525
by Monsieur_x on Tue May 05, 2020 12:18 pm
thank you for the answer! I'll get that soldered today. I'll get back to you to let you know if after the welds it's working.
Monsieur_x
by Monsieur_x on Tue May 05, 2020 3:43 pm
Thank you very much! Now it is well connected.
When I launch the bug file it shows me that the sensor is powered on. Now however the thermocouple shows me this temperature.
Monsieur_x
by adafruit_support_carter on Tue May 05, 2020 4:01 pm
What type of thermocouple are you using?
by Monsieur_x on Tue May 05, 2020 4:34 pm
i've S type and K type but I think type K is broken. Besides, the point of my topic is to use type S
Monsieur_x
by adafruit_support_carter on Tue May 05, 2020 5:03 pm
The default type when not specified is Type K:
https://github.com/adafruit/Adafruit_Ci ... 56.py#L139
If you are using a Type S, change this line:
thermocouple = adafruit_max31856.MAX31856(spi, cs)
to this:
thermocouple = adafruit_max31856.MAX31856(spi, cs, adafruit_max31856.ThermocoupleType.S)
by Monsieur_x on Tue May 05, 2020 6:11 pm
I got the same result after changing the line
Monsieur_x
by adafruit_support_carter on Tue May 05, 2020 6:41 pm
Please post a photo of your soldering on the header pins.
