Black Lives Matter - Action and Equality.
FT232H "...invalid configuration
by ZAPLING on Sat May 02, 2020 2:54 am
I followed the driver installation under circuit python, I can get the board to enumerate with
import usb
import usb.util
dev = usb.core.find(idVendor=0x0403, idProduct=0x6014)
print(dev)
However when I try and use
import board
I get the following error
>>> import board
  File "C:\Users\Sean\AppData\Local\Programs\Python\Python38-32\lib\site-packages\pyftdi\ftdi.py", line 1771, in write_data
    length = self._write(data[offset:offset+write_size])
  File "C:\Users\Sean\AppData\Local\Programs\Python\Python38-32\lib\site-packages\pyftdi\ftdi.py", line 2079, in _write
    return self._usb_dev.write(self._in_ep, data, self._usb_write_timeout)
  File "C:\Users\Sean\AppData\Local\Programs\Python\Python38-32\lib\site-packages\pyusb-1.0.2-py3.8.egg\usb\core.py", line 942, in write
  File "C:\Users\Sean\AppData\Local\Programs\Python\Python38-32\lib\site-packages\pyusb-1.0.2-py3.8.egg\usb\core.py", line 89, in wrapper
  File "C:\Users\Sean\AppData\Local\Programs\Python\Python38-32\lib\site-packages\pyusb-1.0.2-py3.8.egg\usb\core.py", line 203, in setup_request
  File "C:\Users\Sean\AppData\Local\Programs\Python\Python38-32\lib\site-packages\pyusb-1.0.2-py3.8.egg\usb\core.py", line 154, in managed_claim_interface
  File "C:\Users\Sean\AppData\Local\Programs\Python\Python38-32\lib\site-packages\pyusb-1.0.2-py3.8.egg\usb\backend\libusb0.py", line 508, in claim_interface
  File "C:\Users\Sean\AppData\Local\Programs\Python\Python38-32\lib\site-packages\pyusb-1.0.2-py3.8.egg\usb\backend\libusb0.py", line 418, in _check
usb.core.USBError: [Errno None] b'libusb0-dll:err [claim_interface] could not claim interface 0, invalid configuration 0\n'
During handling of the above exception, another exception occurred:
  File "<stdin>", line 1, in <module>
  File "C:\Users\Sean\AppData\Local\Programs\Python\Python38-32\lib\site-packages\board.py", line 129, in <module>
    from adafruit_blinka.board.ftdi_ft232h import *
  File "C:\Users\Sean\AppData\Local\Programs\Python\Python38-32\lib\site-packages\adafruit_blinka\board\ftdi_ft232h.py", line 2, in <module>
    from adafruit_blinka.microcontroller.ft232h import pin
  File "C:\Users\Sean\AppData\Local\Programs\Python\Python38-32\lib\site-packages\adafruit_blinka\microcontroller\ft232h\pin.py", line 71, in <module>
    D4 = Pin(4)
  File "C:\Users\Sean\AppData\Local\Programs\Python\Python38-32\lib\site-packages\adafruit_blinka\microcontroller\ft232h\pin.py", line 24, in __init__
    i2c.configure("ftdi://ftdi:ft232h/1")
  File "C:\Users\Sean\AppData\Local\Programs\Python\Python38-32\lib\site-packages\pyftdi\i2c.py", line 517, in configure
    frequency = self._ftdi.open_mpsse_from_url(url, **kwargs)
  File "C:\Users\Sean\AppData\Local\Programs\Python\Python38-32\lib\site-packages\pyftdi\ftdi.py", line 643, in open_mpsse_from_url
    return self.open_mpsse_from_device(device, interface,
  File "C:\Users\Sean\AppData\Local\Programs\Python\Python38-32\lib\site-packages\pyftdi\ftdi.py", line 764, in open_mpsse_from_device
    frequency = self._set_frequency(frequency)
  File "C:\Users\Sean\AppData\Local\Programs\Python\Python38-32\lib\site-packages\pyftdi\ftdi.py", line 2296, in _set_frequency
    self.write_data(cmd)
  File "C:\Users\Sean\AppData\Local\Programs\Python\Python38-32\lib\site-packages\pyftdi\ftdi.py", line 1778, in write_data
    raise FtdiError('UsbError: %s' % str(ex))
pyftdi.ftdi.FtdiError: UsbError: [Errno None] b'libusb0-dll:err [claim_interface] could not claim interface 0, invalid configuration 0\n'
ZAPLING
Re: FT232H "...invalid configuration
by siddacious on Thu May 07, 2020 5:12 pm
I assume you set the BLINKA_FT232H environment variable as suggested here?
https://learn.adafruit.com/circuitpython-on-any-computer-with-ft232h/windows#set-environment-variable-3-30
I'm not on windows so I can only be so helpful but I'll get this to someone else who can help.
Hold tight!
siddacious
by ZAPLING on Thu May 07, 2020 5:43 pm
Yes,
env var set in cmd window that was used to run python
ZAPLING
by adafruit_support_carter on Thu May 07, 2020 5:44 pm
Is it possible you have some other driver installed that is claiming the FT232H?
After plugging in the FT232H, what does it look like in Device Manager?
by ZAPLING on Fri May 08, 2020 7:45 pm
Screen Shot 2020-05-08 at 4.39.35 PM.png (127.18 KiB) Viewed 24 times
Just like this
ZAPLING
by adafruit_support_carter on Mon May 11, 2020 1:52 pm
That looks OK.
What do you get when you run this?
https://learn.adafruit.com/circuitpytho ... rectly-6-2
by ZAPLING on Mon May 11, 2020 3:45 pm
This is what I get
C:\Users\Sean>python
Python 3.8.2 (tags/v3.8.2:7b3ab59, Feb 25 2020, 22:45:29) [MSC v.1916 32 bit (Intel)] on win32
Type "help", "copyright", "credits" or "license" for more information.
>>> import os
>>> os.environ["BLINKA_FT232H"]
'1'
>>> from pyftdi.ftdi import Ftdi
>>> Ftdi().open_from_url('ftdi:///?')
Available interfaces:
  ftdi://ftdi:232h:1/1   (������)
Then the same error when
import board
is run
ZAPLING
by adafruit_support_carter on Mon May 11, 2020 7:07 pm
What version of Windows are you running?
by ZAPLING on Mon May 11, 2020 7:48 pm
Win 10, latest patch.
I should add that it is a VM on Mac OSX Mavericks
VM ware player .
ZAPLING
by adafruit_support_carter on Mon May 11, 2020 8:01 pm
Can you test with a non-VM instance? The VM layer could be what is causing the interference with low level access to the hardware. It's not a setup we have tested ourselves, so we don't know that will even work.
You can use the FT232H directly on Mac:
https://learn.adafruit.com/circuitpytho ... 2h/mac-osx
by ZAPLING on Mon May 18, 2020 12:27 pm
IT works fine on the MAC - natively.
The challenge is that I have some applications that run in Windows...
ZAPLING
by adafruit_support_carter on Mon May 18, 2020 1:37 pm
I think you are running into issues with the hardware interface specifics that are occurring when running via a virtual machine.
