ByteArray to String Problem
by dsheeran on Sun May 03, 2020 2:11 pm
I am using a Metro M4 Express with a RFM69 radio transceiver to receive commands from a custom built remote control that is also using a RFM69 to send commands.
I am getting responses for only 1 type of command (instead of about 14 different possibilities) but that could be for several reasons.
My question today is how to convert the result of the command received into a string so I can take action on it.
The received string looks like this....
bytearray(b'\x06\x89\xb4\xe9\x92\x0b\xde\x9aH\x19O\x9b')
I cannot seem to decode it. I've used the example in the tutorial for the RFM69 without success. I get a UNICODE exception for that.
I'm attaching a picture of Mu where I get the exception along with the relevant code.
Please help.
byte array.png (64.43 KiB) Viewed 18 times
dsheeran
Re: ByteArray to String Problem
by danhalbert on Sun May 03, 2020 2:42 pm
It looks like you expect the returned bytearray to be alphabetic letters (e.g., like "safety". However, the example you gave is a mix of non alphanumeric or even printing characters.
So I think something else is going wrong, or the remote control is not actually sending readable text back: it's sending some encoded form.
If you just print(packet), what do you see?
You can always do: ` if somebytes == b'safety' `, but that doesn't appear to be what is coming back anyway.
danhalbert
by dsheeran on Sun May 03, 2020 2:55 pm
Strange. The same approach worked in Arduino code. The remote is sending text like "safety".
When I do as you suggested and print(packet) I get this back...
bytearray(b'\x86\x89\xb4\xe9\x92\x0b\xde\x9a\xc8\x99\xcf\x9b')
And other ideas?
dsheeran
by danhalbert on Sun May 03, 2020 3:43 pm
Could you post the Arduino code you are using? There seems to be some difference between what it is receiving and what rfm69.receive() is returning.
danhalbert
by dsheeran on Sun May 03, 2020 4:10 pm
Got it working!
It was the encryption key. It is set in the remote but I hadn't seen it in the tutorial until just now. I set it in the receiver code and voila! Everything is working as designed / expected.
dsheeran
by danhalbert on Sun May 03, 2020 4:50 pm
Great! Glad you got it working!
danhalbert
