Black Lives Matter - Action and Equality.
ADXL345 Accelerometer Range
by Sebastianb28 on Sun May 10, 2020 3:44 pm
I have been playing around with the ADXL345 accelerometer, but I can't set the sensitivity range and data rate properly, I kepep getting an error saying "accelerometer.setRange(ADXL345_RANGE_16_G) - AttributeError: 'ADXL345' object has no attribute 'setRange'
This is code I'm trying to run:
import time
import board
import busio
import adafruit_adxl34x
i2c = busio.I2C(board.SCL, board.SDA)
accelerometer = adafruit_adxl34x.ADXL345(i2c)
accelerometer.setDataRate(ADXL345_DATARATE_3200_HZ)
Sebastianb28
Re: ADXL345 Accelerometer Range
by siddacious on Mon May 11, 2020 2:17 pm
Hi there,
There aren't any "setRange" or "setDataRate" method for the adxl34x library. You'll want to use the 'range' and 'data_rate' properties.
Additionally, the range and data rate constants are organized in classes that are peers to the ADXL345 class so you'll need to import it directly or reference it through the imported 'adafruit_adxl34x' module. While you're at it you can do the same for the ADXL345 class:
import time
import board
import busio
from adafruit_adxl34x import ADXL345, Range, DataRate
accelerometer = ADXL345(i2c)
accelerometer.range - Range.RANGE_16_G
accelerometer.date_rate = DataRate.RATE_3200_HZ
print(accelerometer.acceleration)
May I ask what examples you based your code on? If there is an issue with the documentation or example code we'd like to know so we can fix it.
siddacious
by siddacious on Mon May 11, 2020 2:20 pm
Additionally, the documentation for the ADXL34x library is available here:
https://circuitpython.readthedocs.io/pr ... t/api.html
For future reference, you can find a link to the the documentation for any CircuitPython library in the guide for the sensor in the Adafruit Learning System. As an example, see the "Python Docs" link on the left side of this page:
https://learn.adafruit.com/adxl345-digi ... elerometer
siddacious
