I mounted a Circuit using the NINA B302 + NINA W102 (version 1.6) and followed steps to connect to the AWS IOT.
But i am having the following error (attached)
adafruit_minimqtt.py
line 230
proto, dummy, broker = self.broker.split("/", 2)
What am i doing wrong ? That "/" is where ?
Here my code
- Code: Select all | TOGGLE FULL SIZE
import microcontroller
import time
import json
import board
import busio
from digitalio import DigitalInOut
import neopixel
from adafruit_esp32spi import adafruit_esp32spi
from adafruit_esp32spi import adafruit_esp32spi_wifimanager
import adafruit_esp32spi.adafruit_esp32spi_socket as socket
import adafruit_minimqtt as MQTT
from adafruit_aws_iot import MQTT_CLIENT
### WiFi ###
secrets = {
'ssid' : 'Andreia Oi Miguel 2.4G',
'password' : 'xxxxxxxxxxxx',
"timezone" : "America/New_York", # http://worldtimeapi.org/timezones
"broker" : "xxxxxxxxxxxxxxxxxx-ats.iot.us-east-1.amazonaws.com",
"client_id": "PyPortal"
# Get device certificate
try:
with open("aws_cert.pem.crt", "rb") as f:
DEVICE_CERT = f.read()
except ImportError:
print("Certificate (aws_cert.pem.crt) not found on CIRCUITPY filesystem.")
raise
# Get device private key
try:
with open("private.pem.key", "rb") as f:
DEVICE_KEY = f.read()
except ImportError:
print("Certificate (private.pem.key) not found on CIRCUITPY filesystem.")
raise
# If you are using a board with pre-defined ESP32 Pins:
esp32_cs = DigitalInOut(microcontroller.pin.P0_13)
esp32_ready = DigitalInOut(microcontroller.pin.P0_14)
esp32_reset = DigitalInOut(microcontroller.pin.P1_12)
SCK = microcontroller.pin.P0_07
MOSI = microcontroller.pin.P0_15
MISO = microcontroller.pin.P1_00
spi = busio.SPI(SCK, MOSI, MISO)
esp = adafruit_esp32spi.ESP_SPIcontrol(spi, esp32_cs, esp32_ready, esp32_reset)
# Verify nina-fw version >= 1.4.0
assert (
int(bytes(esp.firmware_version).decode("utf-8")[2]) >= 4
), "Please update nina-fw to >=1.4.0."
wifi = adafruit_esp32spi_wifimanager.ESPSPI_WiFiManager(esp, secrets, None)
### Code ###
topic = "$aws/things/PyPortal/shadow/update"
# Define callback methods which are called when events occur
# pylint: disable=unused-argument, redefined-outer-name
def connect(client, userdata, flags, rc):
# This function will be called when the client is connected
# successfully to the broker.
print("Connected to MQTT Broker!")
print("Flags: {0}\n RC: {1}".format(flags, rc))
# Subscribe to topic circuitpython/aws
print("Subscribing to topic {}".format(topic))
aws_iot.subscribe(topic)
def disconnect(client, userdata, rc):
# This method is called when the client disconnects
# from the broker.
print("Disconnected from MQTT Broker!")
def subscribe(client, userdata, topic, granted_qos):
# This method is called when the client subscribes to a new topic.
print("Subscribed to {0} with QOS level {1}".format(topic, granted_qos))
# Create a json-formatted message
message = {"message": "Hello from AWS IoT CircuitPython"}
# Publish message to topic
aws_iot.publish(topic, json.dumps(message))
def unsubscribe(client, userdata, topic, pid):
# This method is called when the client unsubscribes from a topic.
print("Unsubscribed from {0} with PID {1}".format(topic, pid))
def publish(client, userdata, topic, pid):
# This method is called when the client publishes data to a topic.
print("Published to {0} with PID {1}".format(topic, pid))
def message(client, topic, msg):
# This method is called when the client receives data from a topic.
print("Message from {}: {}".format(topic, msg))
# Set AWS Device Certificate
esp.set_certificate(DEVICE_CERT)
# Set AWS RSA Private Key
esp.set_private_key(DEVICE_KEY)
# Connect to WiFi
print("Connecting to WiFi...")
wifi.connect()
print("Connected!")
# Initialize MQTT interface with the esp interface
MQTT.set_socket(socket, esp)
# Set up a new MiniMQTT Client
client = MQTT.MQTT(broker=secrets["broker"], client_id=secrets["client_id"])
# Initialize AWS IoT MQTT API Client
aws_iot = MQTT_CLIENT(client)
# Connect callback handlers to AWS IoT MQTT Client
aws_iot.on_connect = connect
aws_iot.on_disconnect = disconnect
aws_iot.on_subscribe = subscribe
aws_iot.on_unsubscribe = unsubscribe
aws_iot.on_publish = publish
aws_iot.on_message = message
print("Attempting to connect to %s" % client.broker)
aws_iot.connect()
# Pump the message loop forever, all events
# are handled in their callback handlers
# while True:
# aws_iot.loop()
# Start a blocking message loop...
# NOTE: NO code below this loop will execute
# NOTE: Network reconnection is handled within this loop
while True:
try:
aws_iot.loop()
except (ValueError, RuntimeError) as e:
print("Failed to get data, retrying\n", e)
wifi.reset()
aws_iot.reconnect()
continue
time.sleep(1)
