The demo program here, when run, shows what happens (with only 3 LED's). It successfully starts up (Trial 1), and it successfully changes frequency one time, but when it starts to run the next round (Trial 3) it crashes saying that "All timers are in use". I expected that the carefully programmed "deinit" function calls should have released all timers for re-use, but that's not happening - even though the program reports successful deinit every time.
- Code: Select all | TOGGLE FULL SIZE
import time
import pulseio
import random
# INITIALIZATION
# Define a list of Pulsewidth IO Pins available for use.
PWpins = (board.D7, board.D8, board.D9, board.D10, board.D11,
board.D12)
# Create an empty list for PWM channels, then populate 0-2 with the PWpins
# Defining it outside of a function makes it global so that it
# can be used across and inside functions
PWMChans = []
for i in range(3):
PWMChans.append(PWpins[i])
# Create a list for PWM Output "signals"
PWMOuts = []
for i in range(3):
PWMOuts.append(i)
# How many LEDs will be used
# NOTE: changes will be read from binary switch, to be implemented
# the value of 0 is a guarantee to have it reset
NoLEDs = 3
# FUNCTIONS
# Function to clear all PWMchannels in use (0 - 2) from PWM definitions
# thus preparing them for new assignments.
def PWMClearAll():
for i in range(3):
print("Clearing " + str(i))
PWMOuts[i].deinit()
print("PWMOuts[" + str(i) + "] deinited OK")
time.sleep(1/CurFreq) # Let each channel fully clear
# so that when re-started the pulses will be properly timed with respect
# to each other
# Function to assign pulse width modulation to an arbitrary pin,
# arbitrary duty cycle, and arbitrary frequency.
# CAUTION: This routine assumes the pin is clear (not assigned)
def PWMAssign(pinno, d_c, freq):
print("Attempting to assign " + str(pinno))
PWMCh = pulseio.PWMOut(PWMChans[pinno], duty_cycle=d_c,
frequency=freq)
return PWMCh
# Function to set up channels by frequency and number of channels (NoLEDs)
# NOTE: The intent is to pulse one LED at a time in sequence
def SetupChannels():
# print("SetupChannels was called")
if Trial > 1:
void = PWMClearAll()
PulsW = int(0xFFFF / NoLEDs)
for i in range(NoLEDs):
# print("for loop i = " + str(i))
PWMOuts[i] = PWMAssign(i, PulsW, CurFreq)
time.sleep((1/CurFreq)/NoLEDs)
print("PWMOuts[" + str(i) + "] frequency: "
+ str(PWMOuts[i].frequency))
# MAIN LOOP
Trial = 1
while True:
print("Trial " + str(Trial))
CurFreq = int(10 + 50 * random.random())
SetupChannels()
Trial += 1
time.sleep(1)
