Black Lives Matter - Action and Equality.
I2C device at address
by tultalk on Thu May 14, 2020 7:08 pm
File "<stdin>", line 1, in <module>
File "/usr/local/lib/python3.7/dist-packages/adafruit_ads1x15/ads1x15.py", line 83, in __init__
self.i2c_device = I2CDevice(i2c, address)
File "/usr/local/lib/python3.7/dist-packages/adafruit_bus_device/i2c_device.py", line 69, in __init__
self.__probe_for_device()
File "/usr/local/lib/python3.7/dist-packages/adafruit_bus_device/i2c_device.py", line 192, in __probe_for_device
raise ValueError("No I2C device at address: %x" % self.device_address)
ValueError: No I2C device at address: 48
The device address is hard at 48!!!!!
pi@FarmPI:~ $ sudo i2cdetect -y 1
0 1 2 3 4 5 6 7 8 9 a b c d e f
00: -- -- -- -- -- -- -- -- -- -- -- -- --
10: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
20: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
30: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
40: -- -- -- -- -- -- -- -- UU -- -- -- -- -- -- --
50: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
60: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
70: -- -- -- -- -- -- -- --
pi@FarmPI:~ $
INet search suggested not connecting correct bus (0 or 1)
My device is busnumber 1
Old module allowed setting default busnumber
Don't see that in circuit python code.
How/where to set busnumber?
2nd item:
File "/usr/local/lib/python3.7/dist-packages/adafruit_bus_device/i2c_device.py", line 190, in __probe_for_device
self.i2c.readfrom_into(self.device_address, result)
File "/usr/local/lib/python3.7/dist-packages/busio.py", line 84, in readfrom_into
return self._i2c.readfrom_into(address, buffer, stop=stop)
File "/usr/local/lib/python3.7/dist-packages/adafruit_blinka/microcontroller/generic_linux/i2c.py", line 53, in readfrom_into
readin = self._i2c_bus.read_bytes(address, end - start)
File "/usr/local/lib/python3.7/dist-packages/Adafruit_PureIO/smbus.py", line 178, in read_bytes
self._select_device(addr)
File "/usr/local/lib/python3.7/dist-packages/Adafruit_PureIO/smbus.py", line 163, in _select_device
ioctl(self._device.fileno(), I2C_SLAVE, addr & 0x7F)
OSError: [Errno 16] Device or resource busy
What causes device/resource busy (If it can't find device)?
Best regards
tultalk
Re: I2C device at address
by tultalk on Fri May 15, 2020 11:38 am
Using KNACRO 4-Channel 16Bit ADC with PGA for RPI Raspberry PI 16 Bits I2C ADS1115 Module ADC 4 Channel for Raspberry Pi 3/2 Model B/B+ under 2.7 simpletest.py worked. Changed to SeeedStudio 4-Channel 16-Bit ADC for Raspberry Pi (ADS1115) and get same resource not found under 2.7. At least with Knacro I could easily switch address. With SeeedStrudio, it seem a need to unsolder one bridge and solder another. Pretty stupid.
tultalk
by adafruit_support_carter on Mon May 18, 2020 11:34 am
See here:
https://github.com/adafruit/Adafruit_Bl ... -622096854
https://github.com/adafruit/Adafruit_Py ... tended_Bus
What is the device in question?
by tultalk on Mon May 18, 2020 12:15 pm
A SeedStudio 4 channel 16 bit ADC. But as I stated, 0x48 is "busy" even with the ADC removed.
I saw on another device the 0x48 was a temp sensor and I take not that the RP Pi/Python reports bcm chip temp.
How is that chip temp accessed? Is the sensor on the ic2 bus 1 at 0x48?
I am looking for some tool that reports what (in detail) is at 0x48 on i2c 1
Robert
tultalk
by adafruit_support_carter on Mon May 18, 2020 1:33 pm
Please contact SeedStudio for support with using their ADC.
by tultalk on Tue May 26, 2020 1:58 pm
Not seeed studio. I am using adafruit software.
Every time I shutdown and restart the TB Pi I fund i2cdetect 1 showing uu at 0x48 and the ADC says busy.
If I run sudo rmmod ADS1015 , the uu is cleared and the address 48 shows and the ADC is accessible.
How do I block the ADS1015 form latching onto the kernel?
ps: Fif not like the adafruit 1115 board.
Robert
tultalk
by adafruit_support_carter on Tue May 26, 2020 2:23 pm
Please link to the product page for the specific ADC you are using.
by tultalk on Tue May 26, 2020 2:36 pm
tultalk
by adafruit_support_carter on Tue May 26, 2020 2:48 pm
That is not our hardware. The Adafruit libraries are written for these ADS1x15 breakouts:
https://www.adafruit.com/product/1085
https://www.adafruit.com/product/1083
You'll need to contact Seeed for support with their product.
by tultalk on Tue May 26, 2020 4:08 pm
I ralize that what I am using is not your product. The adafruit library works with 1015 & 1115 boards. I don't like the little breakout boards.
I want something stacked and compact.
I had tried earlier with a Knacro ADC (Same config as the Seeed) and had the same problem. Knacro said to use adafruit library
(KNACRO 4-Channel 16Bit ADC with PGA for RPI Raspberry PI 16 Bits I2C ADS1115 Module ADC 4 Channel for Raspberry Pi 3/2 Model B/B+)
So if I spend $15 on your breakout board and the software exhibits the same problem, will you answer the question:
"Why is this binding to the kerne"l?
tultalk
by tultalk on Tue May 26, 2020 4:30 pm
So I guess I have to blacklist ads1015.
tultalk
by adafruit_support_carter on Tue May 26, 2020 4:35 pm
Yes. We will support our software with our hardware.
Maybe check for any overlays that have been activated in /boot/config.txt? Not sure why the kernel would bind to the ADS on the I2C bus without some prior doing. The basic library shouldn't cause that behavior.
Here's an ADS1115 breakout on a Pi 0 W with Raspbian Lite. It sees the ADS as expected:
pi@pi0:~ $ i2cdetect -y 1
40: -- -- -- -- -- -- -- -- 48 -- -- -- -- -- -- --
and indicates it has not been taken, i.e. no UU return.
by tultalk on Tue May 26, 2020 5:08 pm
Hi:
boot/overlays contains ads1015.dtbo and ads1115.dtbo both dated 2/1620 which is when I installed adafruit software. (git)
Can I just delete these two files?
The original install was from the archive for Python 2.7. I am currently using the new install on 3.7
tultalk
by adafruit_support_carter on Tue May 26, 2020 6:11 pm
Those overlays may be part of the Raspberry Pi firmware:
https://github.com/raspberrypi/firmware ... t/overlays
Where you following a guide for installing the libraries? If so, which one? If not, can you elaborate on what you did here:
by tultalk on Tue May 26, 2020 6:37 pm
I installed the library from git:
First: https://wiki.52pi.com/index.php/RPI-ADS ... KU:EP-0076
Then
sudo apt-get install git build-essential python-dev
cd ~
git clone https://github.com/adafruit/Adafruit_Python_ADS1x15.git
cd Adafruit_Python_ADS1x15
sudo python setup.py install
tultalk
