16ch Servo Bonnet
16ch Servo Bonnet
by cmiller73 on Sat May 16, 2020 2:27 pm
I am using the 16ch servo bonnet. I have installed the Python libraries and partially working, however only able to go to "0°" position. I am using OSSEP LS-0009AF servo. When I try other positions such as 45° or 90°, the servo stops responding.
I also have a DF9GMS continuous rotation servo. Once I start it going one direction, I cannot stop it or reverse it.
Any ideas on what' going on.
cmiller73
Re: 16ch Servo Bonnet
by adafruit_support_carter on Mon May 18, 2020 2:17 pm
Can you post the code you are using to try and control the servo.
by cmiller73 on Mon May 18, 2020 2:35 pm
import time
from adafruit_servokit import ServoKit
kit = ServoKit(channels=16)
kit.servo[0].angle = 45
cmiller73
by adafruit_support_carter on Mon May 18, 2020 2:42 pm
Try running the code below.
The servo only goes to angle 0? Does it even try to move for the other angles?
import time
while True:
    print("angle = 0")
    kit.servo[0].angle = 0
    time.sleep(1)
    print("angle = 45")
    time.sleep(1)
    print("angle = 90")
    kit.servo[0].angle = 90
    time.sleep(1)
by cmiller73 on Mon May 18, 2020 4:02 pm
So I may have identified a problem with my servo. Ordering a new one. Will update when I test the new one. Thanks for your help and quick reply's!!!
cmiller73
by cmiller73 on Mon May 18, 2020 5:27 pm
Actually ended up being a conflict with the i2c address. I had other address same as the servo hat. Jumper-ed A0 on pca, changed address to 0x41 and it works!!! Thanks again.
cmiller73
