Unexplained CircuitPython/NeoPixel error
by flounder on Tue May 19, 2020 1:24 am
This could have been posted in glowy things, or FeatherWing, but it seemed that this was the best forum.
OK, I have the following CircuitPython code. This code is embedded in a double loop that is in the range(0, 32), where start is the outer loop and pixel is the inner loop. The goal is a "lamp test" drawing a spectrum from red to violet on the 32 pixels of a NeoPixel FeatherWing, then repeating it starting one pixel further over. The effect is supposed to be a spectrum that crawls across the display. But I get a runtime error
12. while(True):
14.    for start in range(0, 32):
15.        for pixel in range(0, 32):
18.            print('H = ', H)
19.            HSVcolor = fancy.CHSV(H, 1.0, 1.0)
20.            print('HSVcolor = ', HSVcolor)
21.            RGBcolor = fancy.CRGB(HSVcolor)
22.            print('RGBcolor = ', RGBcolor)
23.            pixels[(start + pixel) % 32] = RGBcolor
24.            pixels.show()
And it produces the following output (I have put the line numbers on the left to show what lines produced the output)
18.     H =  0.0
20.     HSVcolor =  (0.0, 1.0, 1.0)
22.     RGBcolor =  (1.0, 0.0, 0.0)
23.     Traceback (most recent call last):
           File "code.py", line 23, in <module>
           TypeError: object 'CRGB' is not a tuple or list
I'm perplexed. The value returned from HSVcolor is (0.0, 1.0, 1.0), which looks to me like a tuple. This tuple is passed to fancy.CRGB is the tuple returned from HSVcolor. The value returned in RGBcolor is the triple (1.0, 0.0, 0.0), which is pure red (corresponding to H=0.0). So I don't understand the error message.
flounder
Re: Unexplained CircuitPython/NeoPixel error
by dastels on Tue May 19, 2020 11:05 am
RGBcolor is an instance of CRGB, so you'll need to extract the color values from it to set the pixel color, probable RGBcolor.pack().
dastels
by flounder on Sun May 24, 2020 12:45 am
thanks, that worked
flounder
