Black Lives Matter - Action and Equality.
Modules: Where are they?
by tultalk on Tue May 19, 2020 12:17 pm
busio.py (for instance others same imports)
from adafruit_blinka import Enum, Lockable, agnostic
from adafruit_blinka.agnostic import board_id, detector
import adafruit_platformdetect.constants.boards as ap_board
import adafruit_platformdetect.constants.chips as ap_chip
Highlighted modules not in parent modules.
Not anywhere in the dist packages
Where are they? Is this an old module (just installed)?
Robert
tultalk
Re: Modules: Where are they?
by dastels on Tue May 19, 2020 12:24 pm
They're defined in the respective __init__.py
dastels
by tultalk on Tue May 19, 2020 2:17 pm
Hi:
As in here:
detector = adafruit_platformdetect.Detector()
chip_id = detector.chip.id
board_id = detector.board.id
Robert
tultalk
by tultalk on Tue May 19, 2020 2:24 pm
Compile Python 3.7
python -m py_compile "busio.py" (in directory: /usr/local/lib/python3.7/dist-packages)
File "busio.py", line 86
def readfrom_into(self, address, buffer, *, start=0, end=None):
SyntaxError: invalid syntax
Compilation failed.
Suggestion?
tultalk
by tultalk on Tue May 19, 2020 2:49 pm
Never mind. Build cmd was defaulting to 2.7. Changed to 3.7 and Ok.
Regards
tultalk
by tultalk on Tue May 19, 2020 3:45 pm
chips .py contains line BCM_RANGE = {"BCM2708", "BCM2709", "BCM2711", "BCM2835", "BCM2837"}
Why isn't BCM2836 included? Queried in chip.py. Makes no difference?
Robert
tultalk
