lines in CircuitPython
by fid on Tue May 19, 2020 5:08 pm
Greetings,
I wanted to create some animated lines on the screen of the PyGamer that look like falling rain. If I started the raindrop off of the screen it would stop the program because of writing outside the boundaries of the screen. Likewise drawing the raindrops past the bottom of the screen caused the program to stop (fail or crash, whatever you want to call it.) I decided to write a function that would draw the parts of the lines that are only on the screen.
The example will have a set of lines that are radiating from one point well above the screen and terminating below the screen. A second color will have a second set of lines radiating from below the screen and terminating above the screen.
(I had to design and print a new cap for the joystick.)
# screen size is 160x128
import board
import displayio
display = board.DISPLAY
bitmap = displayio.Bitmap(display.width, display.height, 3)
palette = displayio.Palette(3)
palette[0] = 0x000000  # This is the background of the display
palette[1] = 0x8A2BE2  # This is the foreground, Purple
palette[2] = 0xFF0000
# TileGrid for the bitmap
bitmap_grid = displayio.TileGrid(bitmap, pixel_shader=palette)
group = displayio.Group()
group.append(bitmap_grid)
display.show(group)
x1 = 80
y1 = -40
x2 = 0
y2 = 180
x = 0
y = 0
def lineIt(x1, y1, y2, color):
    for x2 in range(-240, 400, 20):
        for y in range(128):
            x = int((((x2 - x1)/(y2 - y1))*(y - y1)) + x1)
            if x > -1 and x < 160:
                bitmap[x, y] = color
lineIt(x1, y1, y2, 1)
lineIt(x1, 180, -40, 2)
while True:
    pass
It won't take much to modify the code to create the animation I was looking for with respect to the raindrops. For a different view of the moire patterns I changed the step in the line that reads for x2 in range(-240, 400, 20) to read for x2 in range(-240, 400, 10). You can also change the colors in the lines beginning with lineIt to be the same to show the moire patterns a little better.
I bumped into Anne Barela on Twitter and she said this is a good place to share code. Thanks Anne.
fid
fid
Re: lines in CircuitPython
by siddacious on Mon May 25, 2020 8:51 pm
Thanks for sharing :)
siddacious
by kevinjwalters on Sat Sep 19, 2020 11:07 am
A lot has been appearing in and around displayio recently including the very new vectorio. What's the recommened / quickest way to draw lines nowadays?
And I'll throw in two other semi-related questions. Is there a way to query/change the update rate for automatic refreshes? And is there a way to retrieve the displayio.Group that's currently being shown, i.e. what was set by display.show(whatever)?
kevinjwalters
