Module Board has not attribute A2
by tultalk on Fri May 22, 2020 5:38 pm
Hi:
python3.7 "busdevice_read_register_spi_simpletest.py" dist packages
#!/usr/bin/env python3
import busio
import board
import digitalio
from adafruit_bus_device.spi_device import SPIDevice
DEVICE_ADDRESS = 0x68  # device address of BMP280 board
A_DEVICE_REGISTER = 0xD0  # device id register on the BMP280 board
# The follow is for SPI communications
cs = digitalio.DigitalInOut(board.A2) [b]<<<<<<<<<<<<<<<<<<<[/b] Module Board has not attribute A2
comm_port = busio.SPI(board.SCK, MOSI=board.MOSI, MISO=board.MISO)
device = SPIDevice(comm_port, cs)
don't understand what "ContextManaged" means here?
class DigitalInOut(ContextManaged):
    _pin = None
    def __init__(self, pin):
        self._pin = Pin(pin.id)
        self.direction = Direction.INPUT
    def switch_to_output(self, value=False, drive_mode=DriveMode.PUSH_PULL):
        self.direction = Direction.OUTPUT
        self.value = value
        self.drive_mode = drive_mode
    def switch_to_input(self, pull=None):
        self.pull = pull
Any help appreciated
Robert
tultalk
Re: Module Board has not attribute A2
by adafruit_support_carter on Fri May 22, 2020 7:29 pm
What board are you running this on? It may not have an A2 pin defined. You can see all the pins with:
dir(board)
(after you've imported board)
ContextManaged is a base class used by the DigitalInOut class. But in general, you shouldn't need worry about the part of the code.
by tultalk on Fri May 22, 2020 8:54 pm
RB Pi 2 B
>>> import board
>>> dir(board)
['CE0', 'CE1', 'D0', 'D1', 'D10', 'D11', 'D12', 'D13', 'D14', 'D15', 'D16', 'D17', 'D18', 'D19', 'D2', 'D20', 'D21', 'D22', 'D23', 'D24', 'D25', 'D26', 'D27', 'D3', 'D4', 'D5', 'D6', 'D7', 'D8', 'D9', 'I2C', 'MISO', 'MISO_1', 'MOSI', 'MOSI_1', 'RX', 'RXD', 'SCK', 'SCK_1', 'SCL', 'SCLK', 'SCLK_1', 'SDA', 'SPI', 'TX', 'TXD', '__builtins__', '__cached__', '__doc__', '__file__', '__loader__', '__name__', '__package__', '__spec__', 'ap_board', 'board_id', 'detector', 'pin', 'sys']
No A2.
tultalk
by tultalk on Sat May 23, 2020 8:38 am
[quote= It may not have an A2 pin defined. [/quote]
Why would this be hard coded if "a board may not have A2 defined"?
No try catch to address the issue!!
Makes no sense
tultalk
by tultalk on Sat May 23, 2020 9:31 am
Never mind. Did not realize what the 280 was.
Sorry
Robert
tultalk
by adafruit_support_carter on Tue May 26, 2020 10:42 am
The Raspberry Pi has no A2 pin.
Different boards will have different sets of pins. If you are following a guide or other information that requires use of an A2 pin, then it is limited to boards with an A2 pin. Otherwise you'll have to adapt the code for the board you are using. Also keep in mind that the Raspberry Pi has no analog inputs at all.
