Black Lives Matter - Action and Equality. ... Adafruit is part of the Stop Hate for Profit campaign. Adafruit is open and shipping.
My Raspberry Pi Can't Detect My I2C Chip
by Israeletu on Fri May 29, 2020 9:01 am
Hello Forum Members,
I want to use ADS1015 ADC chip with Raspberry Pi Zero W. I set up the circuit as shown on the guide, did full upgrade of the Pi and installed the chip's library with: sudo pip3 install adafruit-circuitpython-ads1x15. Everything went successfully.
Then to initialize the ADC chip I went to the IDE of the Pi and typed as follows:
import board
import busio
import adafruit_ads1x15.ads1015 as ADS
from adafruit_ads1x15_in import AnalogIn
i2c = busio.I2C(board.SCL, board.SDA)
ads = ADS.ADS1015(i2c)
chan = AnalogIn(ads, ADS.P0)
print(chan.value, chan.voltage)
The print command is intended to display the raw value and voltage on the P0 input of the ADC chip (because I fed a voltage of 1.16V to it) but the system is complaining of the line:
It says that board has no attribute SCL and SDA.
Please what can I do to initialize the ADC chip and read values from it?
Thank you.
Israeletu
Re: My Raspberry Pi Can't Detect My I2C Chip
by adafruit_support_carter on Fri May 29, 2020 12:03 pm
It sounds like you may have skipped the step to install Blinka:
https://learn.adafruit.com/circuitpytho ... rypi-linux
But based on the error message you are getting, it also sounds like you already have a board module installed. See here for that issue:
https://learn.adafruit.com/circuitpytho ... aq-3055911
by Israeletu on Fri May 29, 2020 4:34 pm
Dear Admin,
Thank you very much for your response. Thanks for responding promptly also. I will take time to follow your advice in detail and thereafter get back to your.
Thanks.
Israeletu
by Israeletu on Sun May 31, 2020 7:00 am
Dear Admin, I have done what you advised and it is now working.
Thank you very much.
Israeletu
