My Raspberry Pi Can't Detect My I2C Chip
by Israeletu on Fri May 29, 2020 9:01 am
Hello Forum Members,
I want to use ADS1015 ADC chip with Raspberry Pi Zero W. I set up the circuit as shown on the guide, did full upgrade of the Pi and installed the chip's library with: sudo pip3 install adafruit-circuitpython-ads1x15. Everything went successfully.
Then to initialize the ADC chip I went to the IDE of the Pi and typed as follows:
import board
import busio
import adafruit_ads1x15.ads1015 as ADS
from adafruit_ads1x15_in import AnalogIn
ads = ADS.ADS1015(i2c)
chan = AnalogIn(ads, ADS.P0)
print(chan.value, chan.voltage)
The print command is intended to display the raw value and voltage on the P0 input of the ADC chip (because I fed a voltage of 1.16V to it) but the system is complaining of the line:
It says that board has no attribute SCL and SDA.
Please what can I do to initialize the ADC chip and read values from it?
Thank you.
Israeletu
Re: My Raspberry Pi Can't Detect My I2C Chip
by adafruit_support_carter on Fri May 29, 2020 12:03 pm
It sounds like you may have skipped the step to install Blinka:
https://learn.adafruit.com/circuitpytho ... rypi-linux
But based on the error message you are getting, it also sounds like you already have a board module installed. See here for that issue:
https://learn.adafruit.com/circuitpytho ... aq-3055911
by Israeletu on Fri May 29, 2020 4:34 pm
Dear Admin,
Thank you very much for your response. Thanks for responding promptly also. I will take time to follow your advice in detail and thereafter get back to your.
Thanks.
Israeletu
by Israeletu on Sun May 31, 2020 7:00 am
Dear Admin, I have done what you advised and it is now working.
Thank you very much.
Israeletu
