How to determine if powered by USB?
by kevinjwalters on Sat May 30, 2020 1:42 pm
Is there a good way to determine if a board is connected to USB power in CircuitPython? I was pondering changing application behaviour a little when not connected to lower the power usage slightly on the assumption that the device is battery powered. Given that the battery and USB power can be simultaneously connected I think I want to avoid an is-battery-connected test?
kevinjwalters
Re: How to determine if powered by USB?
by adafruit_support_bill on Sat May 30, 2020 1:56 pm
You can monitor the voltage on the USB pin with an analog input. Since it will be 5v when connected to USB, you'll need to use a voltage divider to scale it down to 3.3v max.
