Arduino IDE with PyPortal
by Indymx on Tue Jun 02, 2020 9:12 am
Is there a definitive guide for setting up Arduino IDE for use with PyPortal?
I have followed what's on here and am still having errors. Even with the code.py that ships on the pyportal, it's failing. With no modifications to the code.py here's the first error I get:
Arduino: 1.8.12 (Linux), Board: "Adafruit PyPortal M4 (SAMD51), Enabled, 120 MHz (standard), Small (-Os) (standard), 50 MHz (standard), Arduino, Off"
sketch_jun02a:5:3: error: invalid preprocessing directive #Set
# Set up where we'll be fetching data from
sketch_jun02a:10:3: error: invalid preprocessing directive #the
# the current working directory (where this file is)
sketch_jun02a:26:3: error: invalid preprocessing directive #speed
# speed up projects with lots of text by preloading the font!
exit status 1
What am I doing wrong here?
Indymx
Re: Arduino IDE with PyPortal
by dastels on Tue Jun 02, 2020 10:36 am
You're using Python commentting in C++ code. Change the '#' comment characters to '//'.
dastels
by dastels on Tue Jun 02, 2020 10:38 am
I missed it first time... but are you using Python with the Arduino IDE? That won't work. Arduino is just C++. You can use Mu for CircuitPython if you like: https://learn.adafruit.com/welcome-to-circuitpython/installing-mu-editor?preview_token=WsdVgHQVBTr9iHLerIfyWA.
dastels
by Indymx on Tue Jun 02, 2020 10:56 am
I have tried Mu and it doesn't work very well on my system. Not sure why.
If I change the MODE to Adafruit CircuitPython, Mu crashes.
Indymx
by Indymx on Tue Jun 02, 2020 11:09 am
Here's my log:
2020-06-02 11:00:40,053 - mu.logic:1074(select_mode) INFO: New mode selected: adafruit
2020-06-02 11:00:40,070 - root:95(excepthook) ERROR: Unrecoverable error
File "/snap/mu-editor/4/lib/python3.5/site-packages/mu/logic.py", line 1075, in select_mode
self.change_mode(new_mode)
File "/snap/mu-editor/4/lib/python3.5/site-packages/mu/logic.py", line 1112, in change_mode
self.modes[mode].workspace_dir()))
File "/snap/mu-editor/4/lib/python3.5/site-packages/mu/modes/adafruit.py", line 98, in workspace_dir
mount_output = check_output(mount_command).splitlines()
File "/snap/mu-editor/4/usr/lib/python3.5/subprocess.py", line 626, in check_output
**kwargs).stdout
File "/snap/mu-editor/4/usr/lib/python3.5/subprocess.py", line 693, in run
with Popen(*popenargs, **kwargs) as process:
File "/snap/mu-editor/4/usr/lib/python3.5/subprocess.py", line 947, in __init__
restore_signals, start_new_session)
File "/snap/mu-editor/4/usr/lib/python3.5/subprocess.py", line 1551, in _execute_child
raise child_exception_type(errno_num, err_msg)
PermissionError: [Errno 13] Permission denied
There is no "/snap/mu-editor//4/lib/python3.5/site-packages/
Looks like I have a broken install, any ideas how to fix it?
Indymx
by Indymx on Tue Jun 02, 2020 11:37 am
I got it working....
Indymx
