Command line user interface
by rdevries on Tue Jun 02, 2020 4:13 pm
Hello, I am looking for guidance in creating a command line interface using the USB or a UART.
When I do searches for something like this I get pointed to the REPL which doesn't help.
This would be similar to the REPL but a very basic user interface for control.
What would the correct search terms be?
This is a command line which the program is running and gives a terminal prompt for user input.
Format would be CMD Value1 Value2
Or it could be formatted like a JSON string.
Example > DACA 500 -sets the dac channel a to 500
>IO0 1 -sets IO0 to high
>? -help
>ADCA -read the ADC channel a
Or is there a better way? Should I be doing this differently?
The resources I want to keep low and there may not be WiFi or BLE.
Thank you,
rdevries
Re: Command line user interface
by tannewt on Tue Jun 02, 2020 4:20 pm
If you are using CircuitPython, you can get user input over USB with `input()`.
tannewt
by dastels on Tue Jun 02, 2020 4:20 pm
This might be of use/interest/guidance/inspiration: https://learn.adafruit.com/a-cli-in-circuitpython
It works over USB but should be workable over UART.
dastels
by rdevries on Tue Jun 02, 2020 4:33 pm
Thank you tannewt and dastels, I will follow up on both suggestions.
rdevries
by rdevries on Wed Jun 03, 2020 10:46 am
The a-cli-in-circuitpython looks very interesting and so much more capable than what I am looking for. I will need to understand how it works first then I might be able to scale it back. Using the input() is blocking so I would have to see how to use in a different way.
My needs are very basic and need to be non-blocking.
When searching for solutions what key words should I use and where should I look?
Thank you,
rdevries
by tannewt on Wed Jun 03, 2020 2:35 pm
See the bottom of this issue on a way to do it non-blocking: https://github.com/adafruit/circuitpython/issues/231
tannewt
by rdevries on Fri Jun 12, 2020 10:39 am
@tannewt thank you I will have a look. For this project I am working on I will be using a Nextion display and having non-blocking serial would be nice.
I was able to get a simple command line working, its very crude. Adapting the CircuitPython Powered AT Hand-Raiser code https://learn.adafruit.com/AT-Hand-Raiser/circuitpython-code
What I did was split the input string. I need to look into how to make it more elegant but its working. Down side is that when entering a command everything stops.
For this project that can be bad due to some other inputs which can be missed. I will look into 231.
Thank you,
# Start script execution ...
print("Start:")
print(">", end = '')                  # Place > for user cmd line indicator
while True:
    now = time.monotonic()
    if now - inital > interval:               # HB LED flash
        inital = time.monotonic()
        if HbLed.value == True:
                HbLed.value = False
        else:
                HbLed.value = True
    if supervisor.runtime.serial_bytes_available:      # Data available
        inText = input().strip()            # Blocking until a newline is sent
        if inText == "":               # Ignore windows extra parts
            continue
        parse = inText.split()               # parse cmd and operators
        length = len(parse) - 1
        if length == 0:
                cmd = parse[0]
        elif length == 1:
                cmd = parse[0]
                op1 = parse[1]
        elif length == 2:
                cmd = parse[0]
                op1 = parse[1]
                op2 = parse[2]
        elif length == 3:
                cmd = parse[0]
                op1 = parse[1]
                op2 = parse[2]
                op3 = parse[3]
        else:
                print("parse error")
                cmd = ""
        # dac power set
        if cmd.lower().startswith("pwr"):
                PwrSet(op1, op2)
        # adc read
        elif cmd.lower().startswith("adc"):
                ADCRead(op1)
        # stop
        elif cmd.lower().startswith("stop"):
                        Stop()
        # relay ch1
        elif cmd.lower().startswith("rlych1"):
                        RlyCh1(op1)
        # relay ch2
        elif cmd.lower().startswith("rlych2"):
                        RlyCh2(op1)
        # timer
        elif cmd.lower().startswith("tmr"):
                        Tmr(op1, op2)
        # run
        elif cmd.lower().startswith("run"):
                        Run(op1, op2, op3)
        # info
        elif cmd.lower().startswith("info"):
                        Info()
        # help
        elif cmd.lower().startswith("?"):
                        Help()
        # no cmd
        else:
                print("cmd error")
rdevries
