Code only works in REPL
by Tengwar3 on Thu Jun 11, 2020 12:26 am
I have a simple code that i'm learning with to run a motor. The code works in REPL but the code.py file does not run the motor. The LED is green though which says the code.py is running. This is on a Seeed XIAO running CircuitPython 5.3.0. The following file is from the readthedocs.io for 5.0x pulseio Module.
import pulseio
from board import *
pwm = pulseio.PWMOut(D13)
pwm.duty_cycle = 2 ** 15
Been working this for a little longer than I'd like to admit. Thank you for you help.
Tengwar3
Re: Code only works in REPL
by kevinjwalters on Thu Jun 11, 2020 9:53 am
One different between REPL and running a program from code.py from the file system is termination. In REPL things are rather open ended, it takes an explicit Control-D from the interactive user to end the session. A python program terminates when it reaches the last line. That termination triggers various peripherals to reset to their default state. It's common to see
while True:
   pass
at the end of these types of program to prevent termination using this infinite while loop. Whilst infinite loops are highly problematic in many cases for general computing, for a dedicated microcontroller sometimes they make sense. You can still interrupt this with Control-C on the serial console over USB.
kevinjwalters
