How do I change label text
by dougconran on Thu Jun 11, 2020 6:59 pm
I'm stumped! I'm displaying some text on a 1.44" TFT display. I want to be able to update that text without losing everything else eg a graphic. I cannot find any documentation and have tried everything I can think of by hacking around with groups but the best I can come up with is one text label changing at the expense of losing all other text/images on the screen.
My code is:-
font = bitmap_font.load_font("/Rubik-Medium-17.bdf")
soc_txt = "73 %"
tmp_txt = "32 °C"
soh_txt = "99 %"
soc = label.Label(font, text=soc_txt, color=0x70ff70, x=70, y=22)
tmp = label.Label(font, text=tmp_txt, color=0x70ff70, x=70, y=64)
soh = label.Label(font, text=soh_txt, color=0x70ff70, x=70, y=104)
# Create a Group to hold the TileGrid
group = displayio.Group()
# Add the TileGrid to the Group
group.append(tile_grid)
group.append(soc)
group.append(tmp)
group.append(soh)
# Add the Group to the Display
display.show(group)
y = 0
while y < 50:
    soc_txt = str(100-y)+" %"
    print(soc_txt)
    display.show(soc)  <== this changes soc but at the expense of everything else
    y += 1
    time.sleep(0.5)
How can I overwrite these text labels with new values?
Also, the font takes an age to load. I've cut it down as much as I can (although I'm not sure that that has worked). Is there any way I can speed up loading?
dougconran
Re: How do I change label text
by dastels on Thu Jun 11, 2020 7:15 pm
Something along the lines of:
soc.text = "..."
dastels
by dougconran on Thu Jun 11, 2020 7:49 pm
Thanks, I'll try tomorrow as it is a bit late in the UK just now :).
dougconran
by dougconran on Fri Jun 12, 2020 5:44 am
Mmm, I tried that but it gave me a runtime error:-
RuntimeError: Text length exceeds max_glyphs
My adjusted code is:-
while y < 50:
    soc.text = soc_txt
    print(soc_txt)
    y += 1
    time.sleep(0.5)
dougconran
by dougconran on Fri Jun 12, 2020 8:18 am
SOLVED! The problem was that the initial value of the text was 5 characters but it was then being updated with a 5 character string - evidently the initial value sets the max_glyphs value which can't, then, be exceeded. The solution is to make the initial text length as long as it will ever be.
dougconran
by dastels on Fri Jun 12, 2020 10:37 am
Ah right. That makes sense. I had been doing that but to be able to get the width for centering purposes.
dastels
