context manager fails when interrupting input()
by bludin on Fri Jun 12, 2020 5:48 am
The context manager __exit__() of an object is not called when I control-c an input() statement but it works when I control-c any other code within the same context (i.e. with-block for that object). How can I fix that?
bludin
Re: context manager fails when interrupting input()
by tannewt on Fri Jun 12, 2020 11:56 am
Sounds like a bug! Please file an issue here with a test case: https://github.com/adafruit/circuitpython/issues/new
tannewt
by bludin on Sat Jun 13, 2020 5:42 am
I'll do so. I just have to dig a little deeper, because I found that I've been too sloppy.
ctrl-c only takes effect at the input prompt after hitting return. In that case, __exit__() is called as it should. Where it fails is if I hit ctrl-d at the input prompt (only effective when hit before typing anything else). In that case, the program exits without __exit__() being called.
bludin
