building frozen modules make errors
by johncblacker on Sun Jun 14, 2020 3:59 pm
I'm trying to build a micropython that supports the esp32-camera, but I keep getting errors trying to compile various driver files. The compiler is indicating a "SyntaxError" because the first line of some of the .py files in the modules directory is simply a directory "directive" defining where to get the source from. For example the file ntptime.py has a single line:
../../esp8266/modules/ntptime.py
and there are a slew of others that are the same. I surmise that this is supposed to direct the compiler to find the source in the directory defined in the first statement, but that's not a valid python statement that I'm familiar with. Can someone explain this to me and also help me get the make process to work? I don't want to hunt down the source for each of these .py files and copy it to the modules directory for obvious reasons.
johncblacker
Re: building frozen modules make errors
by tannewt on Mon Jun 15, 2020 5:22 pm
I think that may be a symlink rather than a real file. For more MicroPython support I suggest their forum: https://forum.micropython.org/
tannewt
by johncblacker on Mon Jun 15, 2020 7:23 pm
Thanks. The only reason I posted here is that there is a mini-tutorial about writing micropython modules on the Adafruit website, so I figured I'd give it a shot. I did post on the micropython forum, as well. You're absolutely correct. Now that I did a ls -al I can see that the first character is "l" which if I'm correct signifies a link. So, though, if that's the case, why weren't they being resolved correctly during the make process rather than throwing a "SyntaxError?" Apparently during the make process, it's not resolving the link but trying to compile the file and then throws the error...hmmmmm......?
But, anyway, thanks for your reply.
johncblacker
