CircuitPython newbie needs advice
by ramsh on Mon Jun 15, 2020 9:59 am
I'm VERY excited to do my current project with CircuitPython!!!
I'm using Adafruit Feather STM32F405 Express running firmware:
adafruit-circuitpython-bundle-5.x-mpy-20200613
using Mu Editor i successfully run the py version of Blink, awesome!!!!
I've got to the lib part where I wanted to know what libs (from CircuitPython Libraries) are needed from the zip for this project, the board is connected via Qwiic to:
[*]Adafruit ICM-20649 Wide Range ±30g ±4000dps 6-DoF IMU - STEMMA QT / Qwiic
[*]Adafruit LSM303AGR Accelerometer Magnetometer - STEMMA QT Qwiic
it reads analog input from:
Analog 2-axis Thumb Joystick with Select Button + Breakout Board
and lastly, it also should send and receive data through UART
can you please point me the libs i need to copy to the lib folder in CIRCUITPY?
many many thanks in advance!!
best,
Ram
PS,
did i mantion how excited i am to use python on a feather?! :)
ramsh
Re: CircuitPython newbie needs advice
by dastels on Mon Jun 15, 2020 11:29 am
Have a look at the tutorial guides for those sensors. The "Python & CircuitPython" pages will detail what libraries you need and how to install them.
https://learn.adafruit.com/adafruit-icm20649-wide-range-6-dof-imu-accelerometer-and-gyro
https://learn.adafruit.com/lsm303-accelerometer-slash-compass-breakout/
Make sure you're using the latest stable version of CircuitPython (5.3.0 at the moment).
You can have a look at https://learn.adafruit.com/remote-iot-environmental-sensor for examples of using the UART.
dastels
by ramsh on Tue Jun 16, 2020 8:26 am
Many thanks for the links!!
I'm following the tutorial for the ICM20649 and I probably missing something as I get an error, the sensor is connected to the board via Qwiic:
the board CIRCUITPY/lib has the files that are needed to the sensor:
and the code.py has the following example code:
(sorry for using an image for code but when i tried to use the code itself in the message i got this message: "Your message contains banned spam words. Please rephrase your post without the following words: i_c _m" without the underscores)
when I run the code from above I get this error:
Auto-reload is on. Simply save files over USB to run them or enter REPL to disable.
code.py output:
  File "code.py", line 7, in <module>
  File "adafruit_icm20x.py", line 527, in init
  File "adafruit_icm20x.py", line 244, in init
  File "adafruit_icm20x.py", line 249, in initialize
  File "adafruit_icm20x.py", line 275, in _sleep
  File "adafruit_icm20x.py", line 235, in _bank
  File "adafruit_register/i2c_struct.py", line 94, in set
RuntimeError: maximum recursion depth exceeded
can you please point me to what is it I'm missing here?
once again, many thanks for your support!
ramsh
by dastels on Tue Jun 16, 2020 11:21 am
I don't see anything wrong with your code (or your choice of variable names!). Make sure you have the version of the ICM20x library from the latest version of the bundle.
If the problem persists I'll ask around.
dastels
by ramsh on Tue Jun 16, 2020 12:03 pm
i have used the files and folders from June 16, 2020 auto-release (i attached the lib content to this post)
is that the correct version of the ICM20x library?
besides those files is there anything else i need to do for the ICM20x library installation?
lib.zip
(15.04 KiB) Not downloaded yet
ramsh
by dastels on Tue Jun 16, 2020 12:13 pm
That's the latest.
No, if the imports all work, if should be fine. It will complain/stop if it can't find what it needs.
dastels
by ramsh on Tue Jun 16, 2020 12:30 pm
OK, so nothing else from my end I guess, can you please ask around how to solve this?
Thanks again.
Ram
ramsh
by adafruit2 on Tue Jun 16, 2020 1:04 pm
thanks, this is an issue we're aware of and tracking here
https://github.com/adafruit/circuitpython/issues/2830
there's no fix just yet - what exact version of circuitpython are you runing? look at boot.out for that info
adafruit2
Site Admin
by ramsh on Tue Jun 16, 2020 1:28 pm
adafruit2 wrote:thanks, this is an issue we're aware of and tracking here
i'm running version:
Adafruit CircuitPython 5.3.0 on 2020-04-29; Feather STM32F405 Express with STM32F405RG
ramsh
by adafruit2 on Tue Jun 16, 2020 1:31 pm
try the latest 5.4.0 beta
adafruit2
Site Admin
by ramsh on Tue Jun 16, 2020 1:59 pm
adafruit2 wrote:try the latest 5.4.0 beta
the upgrade did the trick!!!!!
Adafruit CircuitPython 5.4.0-beta.1 on 2020-06-08; Feather STM32F405 Express with STM32F405RG
many many thanks!!!
ramsh
