Time.monotonic()
Time.monotonic()
by gordona23 on Wed Jun 17, 2020 6:29 pm
Can you tell me the resolution of the time.monotonic() function on an ItsyBitsy M4? What's the shortest elapsed time that I can reliably measure ? I'm using this to measure pulses from a hall effect sensor on a slowly (300 rpm) spinning motor shaft. Thanks for any help with this.
gordona23
Re: Time.monotonic()
by mikeysklar on Wed Jun 17, 2020 7:20 pm
time.monotonic() is limited to millisecond accuracy.
There should be a time.monotonic_ns() available on Express boards available since CircuitPython 4.x release.
time.monotonic_ns() → int¶
Similar to monotonic(), but return time as nanoseconds.
Good thread on the topic.
https://github.com/adafruit/circuitpython/issues/519
mikeysklar
by kevinjwalters on Wed Jun 17, 2020 7:37 pm
The way that time.monotonic() degrades over time is also described in CLUE Sensor Plotter in CircuitPython: Time in CircuitPython.
kevinjwalters
by tannewt on Thu Jun 18, 2020 1:56 pm
gordona23 wrote:Can you tell me the resolution of the time.monotonic() function on an ItsyBitsy M4? What's the shortest elapsed time that I can reliably measure ? I'm using this to measure pulses from a hall effect sensor on a slowly (300 rpm) spinning motor shaft. Thanks for any help with this.
There are a couple better options than DIY. If you care about pulse length, then pulseio.PulseIn will get down to microseconds or so. If you care about counting pulses then the new `countio` would be your best bet. Note that it's only in the 5.4.0 Beta.
tannewt
by alpierce on Wed Oct 07, 2020 1:36 pm
Is the countio function still only available in 5.4.0 Beta?
alpierce
by tannewt on Wed Oct 07, 2020 8:56 pm
Yup, it's only in the 6.0.0 Beta. Give it a try. It's working well and we're hoping to stabilize soon.
tannewt
by westfw on Thu Oct 08, 2020 6:18 am
time.monotonic_ns()
This wraps in about 4 seconds ?
westfw
by tannewt on Thu Oct 08, 2020 2:04 pm
westfw wrote:
time.monotonic_ns()
No, it uses long integer support so it can be more than 32 bits. It does mean that it won't work on boards without long integer support such as non-Express M0s.
tannewt
