Garbled exception on code.py reload and broken serial consol
by kevinjwalters on Fri Jun 19, 2020 1:47 pm
I've seen this twice now, I very occasionally get garbled output for the errors that can occur with restarting a board from copying code.py to the CIRCUITPY. I've recently switched from drag and drop in windows explorer to powershell's copy but I think I've got one of these errors from both approaches. I'd be interested to know if anyone else gets this? This happens to be on 5.3.0.
code.py output:
  File "code.py", line 1126
IndentationError", line 1126
IndentationErrorst):
I looked into the previous more cryptic one and found it was part of a string used by the CircuitPython interpreter in serial_write_compressed(). The board needs reseting after this to get its USB serial console working again.
I've just noticed the NeoPixel on the back of the CLUE is trying to tell me something, it's "saying": green, yellow, off, white, blue, blue, yellow, yellow, cyan x 6 or 7 times (difficult to count).
Powershell's copy does cause errors on a copy of this fairly large code.py file most of the time but it generally immediately recovers picking up all the change, e.g.
code.py output:
  File "code.py", line 1241
IndentationError: unindent does not match any outer indentation level
Press any key to enter the REPL. Use CTRL-D to reload.soft reboot
code.py output:
...first line of output from the application...
kevinjwalters
Re: Garbled exception on code.py reload and broken serial co
by siddacious on Thu Jun 25, 2020 1:14 pm
Thanks for letting us know. I'll make sure the powers that be see this
siddacious
by AnneBarela on Thu Jun 25, 2020 1:21 pm
Hi Kevin - this appears to be a strange one. Have you dug deeper into what may be causing this? If so, could it boiled down to a "minimum program example" that triggers the error? This will help the devs dive in and see if, indeed, this is the case. And this is for Clue, have you seen it on any other board?
Thanks, Anne
AnneBarela
by kevinjwalters on Thu Jun 25, 2020 1:26 pm
CPB and CLUE on 5.3.0. I posted this mainly to see if others had seen this. The occurrence rate is very low and I'd struggle to guess the factors involved in triggering it. It's possible that it relates to USB comms/drivers but it's not frequent enough to catch with wireshark unless I leave that running all the time!
kevinjwalters
