Connete several Adafruit FT232H Breakout with the one pc
by HocLar on Tue Jun 23, 2020 4:34 am
I'm using the Adafruit FT232H Breakout control another board via GPIO (USB to GPIO converter). So i'm using the libusb and libftdi on windows. It's working with one FT232H Breakout board very well. But it's not working when i use more then one board, i detecte juste one board. I think the problem is that the enumerate_device_serials() function doesn't return the right serial numbers of all board ! .
Does any one a solution to use several Adafruit FT232H Breakout with on PC in the same time ? mybe with pyftdi and pyusb ?
HocLar
Re: Connete several Adafruit FT232H Breakout with the one pc
by siddacious on Thu Jun 25, 2020 12:56 pm
I would suggest that you ask the maintainers of libftdi to determine if using two FT232Hs is a supported use case, and if so what requirements they have for it to work.
https://www.intra2net.com/en/developer/libftdi/
siddacious
