Multitasking
Multitasking
by Rcayot on Tue Jun 23, 2020 7:57 am
There is a great series by Bill Earl called multitasking on arduino. Is there something similar for circuitpython?
I have done a bit of beginner arduino programming, and would like to move to CP because of all of the great products and supporting libraries at Adafruit. I have yet to find, however, a good guide to using classes for multitasking using CP. and the new years eve drop ball example does not help me, it is more of a state machine example.
Also, any other resources on that subject would be helpful. Most online python resources do not address aspects of physical computing.
Roger Ayotte
Rcayot
Re: Multitasking
by adafruit_support_bill on Tue Jun 23, 2020 9:39 am
State machines are the key to multitasking in a purely single-threaded environment. The state machine classes in Dave's ball-drop tutorial are structured a little differently from the state machines in my Multitasking the Arduino series. But overall effect is similar. The main processing loop just needs to call the update function.
To make it multitask, you create multiple state machines and call update on all of them.
Re: Multitasking
by tannewt on Tue Jun 23, 2020 2:02 pm
Hi Roger,
CircuitPython doesn't support any of Python's concurrency mechanics. There is a long issue about it here if you are interested: https://github.com/adafruit/circuitpython/issues/1380
~Scott
tannewt
Re: Multitasking
by AndyWilx on Mon Aug 10, 2020 9:01 am
Hi all
I hope someone can help.
I'm an artist working on a project that requires two NeoPixel strips running two animations simultaneously.
Bill's Multitasking sketch is perfect and I've been able to change Rings to Strips, remove the button functions and play with the patterns included.
However, I need a new pattern integrated into the code and have no idea how to make it work.
I'm not a coder and am struggling.
Below is the pulse code I want to assign to one of the strips.
Can anyone help or point me in the right direction?
It would be very much appreciated
Thanks Guys
Andy Wilx
#define PIN 6
#define NUMPIXELS 12
Adafruit_NeoPixel strip = Adafruit_NeoPixel(NUMPIXELS, PIN, NEO_GRB + NEO_KHZ800);
int dir = 1;
int bright = 50;
strip.begin();
strip.show();
uint32_t blueFade = strip.ColorHSV(43650,255,bright);
strip.fill(blueFade);
strip.show();
bright = bright + dir;
if(bright > 100 || bright < 10) dir = dir * -1;
delay(25);
AndyWilx
Re: Multitasking
by adafruit_support_bill on Mon Aug 10, 2020 11:31 am
You can accomplish that effect using the Fade pattern from the guide: https://learn.adafruit.com/multi-taskin ... rt-3/fader
Set color1 to be your brightest blue color and color2 to be the dimmest and use an interval of 25.
Re: Multitasking
by AndyWilx on Tue Aug 11, 2020 5:02 am
Thanks for coming back to me.
I have done that and it obviously works as a fade but not a pulse.
It's not quite the same effect as it fades off, then pops on.
This is more subtle as the end point isn't quite off so looks like a pulse not a fade.
Also how do I keep it to one colour?
I'm after a single colour heartbeat.
I guess where I struggle with this type of code, is the lack of tangible variables. A string of words rather than percentages and values.
I'll clearly never be a coder. ;o)
Any help will be very much appreciated.
Andy
AndyWilx
Re: Multitasking
by adafruit_support_bill on Tue Aug 11, 2020 5:53 am
The fade lets you set the end point to any arbitrary color. color2 does not need to be black. If you want more of a 'breathing' effect, just reverse the direction on completion.
You specify the start color (color1) and the end color (color2). They can be different shades of the same color.
Re: Multitasking
by AndyWilx on Wed Aug 12, 2020 6:40 am
Thanks again for the reply.
I've got it to fix to one color, (simply turn off the random update).
But this isn't the same animation. This is a fade not a pulse.
Fade: 3-2-1-off-3-2-1-off
Pulse: 3-2-1-off-1-2-3-2-1-off-1-2-3
See my original code.
Apologies if I'm not able to see it in your code.
I'm not a coder.
I'm so close I can smell it but my lack of knowledge is frustrating.
Help would be very welcome.
Andy
AndyWilx
Re: Multitasking
by adafruit_support_bill on Wed Aug 12, 2020 7:07 am
It's hard to offer specific advice since you haven't posted your code.
There is nothing random in the fade pattern. It does what you program it to do.
AS mentioned in my previous post, If you want a breathing effect, simply reverse the fade on completion.
https://learn.adafruit.com/multi-taskin ... -1167790-9
if (strip.Direction == FORWARD)
   strip.Direction = REVERSE;
else
  strip.Direction = FORWARD;
Re: Multitasking
by AndyWilx on Wed Aug 12, 2020 8:41 am
2_animations_NOBUTTON.ino
(8.58 KiB) Downloaded 2 times
OK, I didn't want to do this but please find attached my code, (well, your code really with my clumsy hacks).
I'm after:
Strip 1 Rainbow Cycle (I'll want to add audio responsive code next ;o)
Strip 2 Pulsing heart beat in one colour.
P.S.
I didn't mean your code was random, I meant removing the 'Random' Call Back seemed to work for me.
"Stick.Color1 = Stick.Wheel(random(255));"
Many Many thanks for your help.
Andy
// Pattern types supported:
enum  pattern { NONE, RAINBOW_CYCLE, THEATER_CHASE, COLOR_WIPE, SCANNER, FADE };
// Patern directions supported:
enum  direction { FORWARD, REVERSE };
// NeoPattern Class - derived from the Adafruit_NeoPixel class
class NeoPatterns : public Adafruit_NeoPixel
    public:
    // Member Variables:
    pattern  ActivePattern;  // which pattern is running
    direction Direction;     // direction to run the pattern
    unsigned long Interval;   // milliseconds between updates
    unsigned long lastUpdate; // last update of position
    uint32_t Color1, Color2;  // What colors are in use
    uint16_t TotalSteps;  // total number of steps in the pattern
    uint16_t Index;  // current step within the pattern
    void (*OnComplete)();  // Callback on completion of pattern
    // Constructor - calls base-class constructor to initialize strip
    NeoPatterns(uint16_t pixels, uint8_t pin, uint8_t type, void (*callback)())
    :Adafruit_NeoPixel(pixels, pin, type)
        OnComplete = callback;
    // Update the pattern
    void Update()
        if((millis() - lastUpdate) > Interval) // time to update
            lastUpdate = millis();
            switch(ActivePattern)
                case RAINBOW_CYCLE:
                    RainbowCycleUpdate();
                    break;
                case THEATER_CHASE:
                    TheaterChaseUpdate();
                    break;
                case COLOR_WIPE:
                    ColorWipeUpdate();
                    break;
                case SCANNER:
                    ScannerUpdate();
                    break;
                case FADE:
                    FadeUpdate();
                    break;
                default:
                    break;
    // Increment the Index and reset at the end
    void Increment()
        if (Direction == FORWARD)
           Index++;
           if (Index >= TotalSteps)
                Index = 0;
                if (OnComplete != NULL)
                    OnComplete(); // call the comlpetion callback
        else // Direction == REVERSE
            --Index;
            if (Index <= 0)
                Index = TotalSteps-1;
    // Reverse pattern direction
    void Reverse()
        else
            Index = 0;
    // Initialize for a RainbowCycle
    void RainbowCycle(uint8_t interval, direction dir = FORWARD)
        ActivePattern = RAINBOW_CYCLE;
        Interval = interval;
        TotalSteps = 255;
        Index = 0;
        Direction = dir;
    // Update the Rainbow Cycle Pattern
    void RainbowCycleUpdate()
        for(int i=0; i< numPixels(); i++)
            setPixelColor(i, Wheel(((i * 256 / numPixels()) + Index) & 255));
        show();
        Increment();
    // Initialize for a Theater Chase
    void TheaterChase(uint32_t color1, uint32_t color2, uint8_t interval, direction dir = FORWARD)
        ActivePattern = THEATER_CHASE;
        TotalSteps = numPixels();
        Color1 = color1;
        Color2 = color2;
        Index = 0;
        Direction = dir;
    // Update the Theater Chase Pattern
    void TheaterChaseUpdate()
            if ((i + Index) % 3 == 0)
                setPixelColor(i, Color1);
            else
                setPixelColor(i, Color2);
        show();
        Increment();
    // Initialize for a ColorWipe
    void ColorWipe(uint32_t color, uint8_t interval, direction dir = FORWARD)
        ActivePattern = COLOR_WIPE;
        Color1 = color;
        Index = 0;
        Direction = dir;
    // Update the Color Wipe Pattern
    void ColorWipeUpdate()
        setPixelColor(Index, Color1);
        show();
        Increment();
    // Initialize for a SCANNNER
    void Scanner(uint32_t color1, uint8_t interval)
        ActivePattern = SCANNER;
        TotalSteps = (numPixels() - 1) * 2;
        Color1 = color1;
        Index = 0;
    // Update the Scanner Pattern
    void ScannerUpdate()
        for (int i = 0; i < numPixels(); i++)
            if (i == Index)  // Scan Pixel to the right
            else if (i == TotalSteps - Index) // Scan Pixel to the left
            else // Fading tail
                 setPixelColor(i, DimColor(getPixelColor(i)));
        show();
        Increment();
    // Initialize for a Fade
    void Fade(uint32_t color1, uint32_t color2, uint16_t steps, uint8_t interval, direction dir = FORWARD)
        ActivePattern = FADE;
        TotalSteps = steps;
        Color1 = color1;
        Color2 = color2;
        Index = 0;
        Direction = dir;
    // Update the Fade Pattern
    void FadeUpdate()
        // Calculate linear interpolation between Color1 and Color2
        // Optimise order of operations to minimize truncation error
       uint8_t red = ((Red(Color1) * (TotalSteps - Index)) + (Red(Color2) * Index)) / TotalSteps;
        uint8_t green = ((Green(Color1) * (TotalSteps - Index)) + (Green(Color2) * Index)) / TotalSteps;
       uint8_t blue = ((Blue(Color1) * (TotalSteps - Index)) + (Blue(Color2) * Index)) / TotalSteps;
       ColorSet(Color(red, green, blue));
       show();
       Increment();
    // Calculate 50% dimmed version of a color (used by ScannerUpdate)
    uint32_t DimColor(uint32_t color)
        // Shift R, G and B components one bit to the right
        uint32_t dimColor = Color(Red(color) >> 1, Green(color) >> 1, Blue(color) >> 1);
        return dimColor;
    // Set all pixels to a color (synchronously)
    void ColorSet(uint32_t color)
            setPixelColor(i, color);
        show();
    // Returns the Red component of a 32-bit color
    uint8_t Red(uint32_t color)
        return (color >> 16) & 0xFF;
    // Returns the Green component of a 32-bit color
    uint8_t Green(uint32_t color)
        return (color >> 8) & 0xFF;
    // Returns the Blue component of a 32-bit color
    uint8_t Blue(uint32_t color)
        return color & 0xFF;
    // Input a value 0 to 255 to get a color value.
    // The colours are a transition r - g - b - back to r.
    uint32_t Wheel(byte WheelPos)
        WheelPos = 255 - WheelPos;
        if(WheelPos < 85)
            return Color(255 - WheelPos * 3, 0, WheelPos * 3);
        else if(WheelPos < 170)
            WheelPos -= 85;
            return Color(0, WheelPos * 3, 255 - WheelPos * 3);
        else
            WheelPos -= 170;
            return Color(WheelPos * 3, 255 - WheelPos * 3, 0);
void Strip1Complete();
void Strip2Complete();
NeoPatterns Strip1(12, 5, NEO_GRB + NEO_KHZ800,  &Strip1Complete);
NeoPatterns Strip2(12, 6, NEO_GRB + NEO_KHZ800,  &Strip2Complete);
void setup()
    Strip1.begin();
    Strip2.begin();
    // Kick off a pattern
    //THEATERCHASE
    //Strip2.TheaterChase(Strip1.Color(255,255,0), Strip2.Color(0,0,50), 100);
    //RAINBOWCYCLE
    Strip1.RainbowCycle(10);
    Strip1.Color1 = Strip1.Color1;
    //SCANNER
    //Strip2.Scanner(Strip2.Color(50,0,255), 255);
    //FADE
    Strip2.ActivePattern = FADE;
        Strip2.Interval = 100;
// Main loop
void loop()
    // Update the Strips.
    Strip1.Update();
    Strip2.Update();
// Strip1 Completion Callback
//Strip2 Completion Callback
  if (Strip2.Direction == FORWARD)
   Strip2.Direction = REVERSE;
else
  Strip2.Direction = FORWARD;
Last edited by adafruit_support_bill on Wed Aug 12, 2020 8:46 am, edited 1 time in total.
Reason: added code in-line
AndyWilx
Re: Multitasking
by adafruit_support_bill on Wed Aug 12, 2020 8:54 am
    //FADE
You are calling the initialization for Scanner which takes just one color and an interval. You should be calling the initialization for the Fader which lets you configure both colors, as well as the number of steps, direction and interval for your fade. https://learn.adafruit.com/multi-taskin ... -1167113-2
    //FADE - bright blue to dim blue - 100 steps - 10 ms per step
    Strip2.Fade(Strip2.Color(50,0,255), Strip2.Color(0,0,25), 100, 10, FORWARD);
Re: Multitasking
by AndyWilx on Thu Aug 13, 2020 4:05 am
That's great thank you.
And does the:
else
Code go into the Completion Callback?
I've put it there and then just cycles in reverse.
I had a fiddle with defining the reverse in the Callback, which I can see is ugly and not good code but it worked properly for one cycle. It then just loops in reverse.
if (Strip2.Color(0,0,25))
// Strip2.Direction = REVERSE;
Strip2.Fade(Strip2.Color(0,0,25), Strip2.Color(0,0,255), 100, 10);
else
I'm assuming I'm not defining what FORWARD is in the main loop?
(8.67 KiB) Not downloaded yet
AndyWilx
Re: Multitasking
by adafruit_support_bill on Thu Aug 13, 2020 11:41 am
This should work:
   else
Re: Multitasking
by AndyWilx on Fri Aug 14, 2020 4:31 am
I tried that first and it doesn't.
this is the result:
3-2-1-flicker-1-2-3
1-2-3
1-2
1-2
1-2-3
1-2-3
1-2
1-2
If I add
else
Strip2.Fade(Strip2.Color(0,0,255), Strip2.Color(0,0,25), 100, 10);
I get:
3-2-1-2-3
1-2-3
1-2-3
1-2-3
Frustratingly close.
AndyWilx
Re: Multitasking
by adafruit_support_bill on Fri Aug 14, 2020 8:33 am
Try this:
     Strip2.Index = Strip2.TotalSteps-1;
   else
     Strip2.Index = 0;
