PN532 using IRQ pin
PN532 using IRQ pin
by shaul on Thu Jul 02, 2020 7:12 am
Hi. We are attempting to read multiple PN532 cards using the IRQ pin to know which one has a tag near it. What we are seeing is that the IRQ pin does go low as expected, but that happens only once. The next time(s) a tag is brought to the reader, the IRQ stays high.
What are we missing? Help would be much appreciated.
shaul
Re: PN532 using IRQ pin
by siddacious on Thu Jul 02, 2020 11:24 am
Please post your full code using the '[code]' tags for formatting as well as clear, well lit photos that show all of the connections. There's a lot that could be going on in hardware or software so we'll need to see whats up with both to assess the situation
siddacious
by shaul on Sun Jul 05, 2020 11:24 am
############### RFIDReader.py ###############
import threading
from MCPPNLIB import ReadersSet
from MCP23S17 import MCP23S17
import binascii
import sys
import time
# Setup  PN532
MISO = 19 #BCM pins on RPI
MOSI = 20 #BCM pins on RPI
SCLK = 21 #BCM pins on RPI
CS = [6] # BCM pins on RPI
MCPIRQ = [8] # MCP pin 0 = GPA0, 8=GPB0 ....(0-15)
class RFIDReader(threading.Thread):
  def __init__(self, group=None, target=None, name=None, args=(), kwargs=None, verbose=None):
    super(RFIDReader,self).__init__(group=group, target=target, name=name)
    self.mcp = MCP23S17(bus=0x00, pin_cs=0x00, device_id=0x01)
    self.mcp.open()
    self.readers = ReadersSet(MISO,MOSI,SCLK,CS,MCPIRQ,self.mcp)
    self.readers.begin()
  def run(self):
    print("Reader starting")
    lastRead = 0
    while True:
      time.sleep(0.2)
      # get new read flag
      newRead, mcpirq,  uid = Readers.isNewRead()
      if (newRead && uid!=lastRead):
        print("new read on irq:", mcpirq, " uuid:",format(binascii.hexlify(uid)) )
        lastRead = uid
if __name__ == "__main__":
  def close(signal, frame):
    sys.exit(0)
  signal.signal(signal.SIGINT, close)
  rif = RFIDReader()
  rif.setDaemon(True)
  rif.start()
############################# MCPPNLIB.py
import binascii
import sys
import time
import threading
import Adafruit_PN532 as PN532
class readers:
    def __init__(self, pn, mcpirq):
        self.pn = pn
        self.mcpirq = mcpirq
class ReadersSet(object):
    global readers
    def __init__(self,MISO = 19, MOSI=20, SCLK=21,CS=[],MCPIRQ=[], mcp1 = MCP23S17 ):
        # Setup  data
        self.MISO = MISO
        self.MOSI = MOSI
        self.SCLK = SCLK
        self.CS = CS
        self.MCPIRQ = MCPIRQ
        self.mcp1 = mcp1
        self.readerMCPIRQ = 99
        self.lastUid = 0
        # creating list
        self.readersList = []
        # appending instances to list
        for i in range(len(self.CS)):
            self.readersList.append(readers(PN532.PN532(cs=self.CS[i], sclk=self.SCLK, mosi=self.MOSI, miso=self.MISO),self.MCPIRQ[i]))
        # Call begin to initialize communication with the PN532.
        for reader in self.readersList:
            reader.pn.begin()
        #get version
            ic, ver, rev, support = reader.pn.get_firmware_version()
            print('Found PN532 with firmware version: {0}.{1}'.format(ver, rev))
        # Configure PN532 to communicate with MiFare cards.
            reader.pn.SAM_configuration()
        # get tem into stand by mode for reading
            uid = reader.pn.read_passive_target(0)
        # stop thread flag
        self.stop_threads = False
    def thread_function(self,name):
        while (True):
            if (self.stop_threads):
                break
            # read all 16 pins of the MCP
            pinsValue = self.mcp1.readGPIO()
            #print("T:",bin(pinsValue))
            # go over list of readers
                #if any is avilable
                if not pinsValue & 1<<(reader.mcpirq) :
                    uid = reader.pn.read_passive_target()
                    # Try again if no card is available.
                    if uid is not None:
                        print("READER ", reader.mcpirq)
                        print('Found card with UID: 0x{0}'.format(binascii.hexlify(uid)))
                        self.readerMCPIRQ = reader.mcpirq
                        self.lastUid = uid
                    # set it back to stand by
            #thread sleeping time to allow system to work
            time.sleep(0.01)
    def begin(self):
        x = threading.Thread(target=self.thread_function, args=(1,))
        x.start()
    def stop(self):
        self.stop_threads = True
    def onExit(self):
    def isNewRead(self):
        if self.readerMCPIRQ !=99:
            tempIRQ = self.readerMCPIRQ
            self.readerMCPIRQ = 99 # reset
            return True, tempIRQ, self.lastUid
        else:
            return False, 0, 0
shaul
