Using Circuit Python with RasPi and RockBlock script send me
by ChadRT78 on Fri Jul 24, 2020 2:54 pm
Hello I am attempting to use a script that I have imported to my RasPi 3b+ to work with the RockBlock unit. I only need two modifications and I have made one of them successfully but other is not working for me. I will admit that I am not a python guy and this is my first time working with Python in general. So here goes...
#!/usr/bin/python3
import sys
# pylint: disable=wrong-import-position
import time
# CircuitPython / Blinka
import board
import serial
uart = serial.Serial("/dev/serial0", 19200)
from adafruit_rockblock import RockBlock
rb = RockBlock(uart)
# set the text
rb.out_text = sys.argv[1]
# try a satellite Short Burst Data transfer
print("Talking to satellite...")
status = rb.satellite_transfer()
# loop as needed
retry = 0
while status[0] > 8:
    time.sleep(10)
    print(retry, status)
    retry += 1
print("\nDONE.")
I added the first line and I am attempting to make the body of the message able to be sent via the command line. In PHP or BASH I can accomplish this by utilizing variables. I have found nearly identical capability but implementing this is proving to be a challenge. As you can see I have "import sys" to make use of the sys.argv[x] but I need the entire string not including the file name to be sent to the RockBlock. Can anyone point me in the direction I need to be headed.
I have confirmed that leaving it the way it comes with a shebang at the top to make entry simpler. I have also made it executable and placed it into my user/bin folder for ease of operation. Then it just works.
The idea is to be able to:
root@rockblock-pi:~# satsend This is where my message is supposed to be!
I only get a "[No payload]" in my dashboard when I try using the string from the commandline.
So last but not least I hope this is the right forum for this :)
ChadRT78
Re: Using Circuit Python with RasPi and RockBlock script sen
by ChadRT78 on Fri Jul 24, 2020 3:45 pm
OK so I stand corrected! It does not work with the original "hello world" example. it also delivers the "no payload" I dont know where I could have gone wrong now. LOL :D
These work just fine:
rockblock_recv_text.py
rockblock_simpletest.py
and I have even in the past few minutes been able to create a few more (copy/paste coding) for signal checks, clearing the buffers etc.
Edit: When I use the rockblock_send_data.py I get the following posted to my php application on my site...
@k~(B hello world
and
This is what shows in the dashboard of the RockBlock console...
400800006b7e28420b00000068656c6c6f20776f726c64
ChadRT78
