This is the second alpha release of CircuitPython 6.0.0. It is alpha because we are planning one more API change to
ulab. It is relatively stable.
Feature-wise, this stable release adds basic lower power support when in
time.sleep() and initial ESP32-S2 support. The lower power work changed time keeping and may have introduced bugs. Please use 5.3.0 if you need a stable version of CircuitPython.
Download from circuitpython.orgDownloads are available from
circuitpython.org! The site makes it easy to select the correct file and language for your board. The downloads page is
here. Downloads are no longer available from the GitHub release pages because of the large number of files for each release.
InstallationTo install follow the instructions in our new
Welcome to CircuitPython! guide. To install the latest libraries, see
this page in that guide.
Try
the latest version of the Mu editor for creating and editing your CircuitPython programs and for easy access to the CircuitPython serial connection (the REPL).
New features and improvements since 6.0.0 Alpha 1API Changes- Disable socket, wiznet5k and network modules. They will be removed in 7.x in favor of networking libraries. Thanks to @tannewt
- Add memorymonitor for memory debugging. It must be enabled on a local build. Thanks to @tannewt
- Add .find, .rfind, .index and .rindex to bytearray for CPYTHON compatible builds. Thanks to @tannewt
- json.load now works with any object with readinto. Thanks to @tannewt
Internals- Improved performance with background task rework. Now on par with 5.3.x Thanks to @jepler
- Enable PYSTACK which separates python code state from C code state and improves memory use. Let us know if you hit a RuntimeError from an exhausted pystack. It may be too small. Thanks to @tannewt
Fixes- ESP32S2 build can now be parallelized. Thanks to @jepler
- ESP32S2 unique IDs are now actually unique. Thanks to @jepler
- Fixed VectorShape non-transposed pixel placement. Thanks to @warriorofwire
- Fixed USB starvation during long numeric calculations. Thanks to @daveputz
- Fixed Polygon.points. Thanks to @WarriorOfWire
- SAMD brown out levels are now configurable. Thanks to @deshipu
- MP3 playback improvements. Thanks to @jepler
- PulseIn fixed on SAMD. Thanks to @DavePutz
Board changes- Enable analogio on PewPew M4. Thanks to @deshipu
- Seeed Wio Terminal display now init by default. Thanks to @ansonhe97
Documentation- License documentation improvements. Thanks to @flameeyes
- Improve generated .pyi files. Thanks to @ciscorn
- Additional type hints to the core docs. Thanks to @dherrada
- Documentation improvements. Thanks to AndrewR-L, @dkhawk and @dunkmann00
- Dutch, Indonesian, Portuguese, Spanish, and Swedish translation improvements. Thanks to @bergdahl, @fede2cr, @oonid, @ryevertigo, and @wtuemura.
Full commit log is
here.
Breaking changes since 5.x- i2cslave is now i2cperipheral and the class in it is changed as well.
- The stop kwarg has been removed from I2C.writeto(). If no stop is desired, then use writeto_then_readfrom.
New boards since 6.0.0 Alpha 1Known Issues- displayio operations that read from an SD card (e.g., OnDiskBitmap) will interfere with other SD card operations and can cause lockup. To work around this problem, do not read or write files on the SD while the display is updating, and vice versa.
- See https://github.com/adafruit/circuitpython/issues for other issues.
ThanksThank you to all who used, tested,
contributed since 6.0.0 Alpha 1, helped out, and participated on GitHub and/or Discord, including @ansonhe97, @arms22 @Arudinne, @bergdahl, @ciscorn, @DavePutz, @deshipu, @dhalbert, @dherrada, @dkhawk, @dunkmann00, @fede2cr, @flameeyes, @jepler, @ladyada, @oonid, @ryevertigo, @tannewt, @TinkeringTech, @warriorofwire, @wtuemura and @xiongyihui and surely more we have missed. Join us on the
Discord chat to collaborate.
DocumentationDocumentation is available
in readthedocs.io.
This release is based on
MicroPython 1.9.4 @25ae98f. Support upstream MicroPython by purchasing
a PyBoard (from Adafruit
here) or
sponsoring MicroPython on GitHub.
TranslationsOne important feature of CircuitPython is translated control and error messages. With the help of fellow open source project
Weblate, we're making it even easier to add or improve translations. Sign in with an existing account such as Github, Google or Facebook and
start contributing through a simple web interface. No forks or pull requests needed!
TroubleshootingCheck out
this guide for info on common problems with CircuitPython. If you are still having issues, then post to the
Adafruit Support Forums and join
Discord.
AssetsBuilds are no longer stored as assets on this release page, because there are too many of them. Please see the Download from circuitpython.org section above.
