BLE Scan not picking up all devices
by dougconran on Sat Jul 25, 2020 5:57 pm
I am using the example ble_detail_scan program from the from the 5 series circuitpython examples folder and running it on an itsybitsynrf52840. That is detecting 2 and sometimes 3 bluetooth devices (2 of which are Windows 10 desktops) whereas nRF Connect lists 7 or more devices. Why would that be and are there any scan parameters I can set to pick up more?
dougconran
Re: BLE Scan not picking up all devices
by tannewt on Mon Jul 27, 2020 4:33 pm
It's possible the settings are different. Are the devices that are missed nearby or distant?
tannewt
by dougconran on Mon Jul 27, 2020 5:01 pm
They are certainly more distant than those it was picking up. Also it did pick up the microcontroller I was testing so this question is probably redundant at the moment. - thanks, though for your reply.
dougconran
by kevinjwalters on Mon Aug 03, 2020 11:01 am
You could experiment with different rssi values. The default on minimum_rssi on start_scan() is -80. Try adding something like minimum_rssi=-100 to extend the range.
I've noticed my android tablet is much more sensitive than my nRF52840 based Adafruit boards.
kevinjwalters
by dougconran on Mon Aug 03, 2020 11:31 am
Thanks and I'll give that a try but, as it happens, it is now picking up the device. I just need to keep it close by.
dougconran
