Precompiled versions of mpy-cross for CP 4, 5, 6
by kevinjwalters on Mon Jul 27, 2020 7:12 am
For CircuitPython 2 and 3 there are precompiled versions of mpy-cross available on Creating and sharing a CircuitPython library: Overview. Is there a place to download mpy-cross for versions 4, 5, 6? My understanding is the current recommendation is to match the mpy-cross version to the major version number as there can be changes in bytecode (.mpy) format, is that correct?
There are instructions for compiling on Building CircuitPython: Build CircuitPython and Adafruit Forums: how to precompile a .py file to a .mpy file Windows 10. Those might be a bit involved for a portion of the CircuitPython audience.
Are there any plans to change the name of mpy-cross? It clashes with MicroPython's mpy-cross. I presume pip install mpy-cross is NOT the answer here for CircuitPython as it gets the MicroPython incarnation?
kevinjwalters
Re: Precompiled versions of mpy-cross for CP 4, 5, 6
by tannewt on Mon Jul 27, 2020 4:49 pm
kevinjwalters wrote:For CircuitPython 2 and 3 there are precompiled versions of mpy-cross available on Creating and sharing a CircuitPython library: Overview. Is there a place to download mpy-cross for versions 4, 5, 6? My understanding is the current recommendation is to match the mpy-cross version to the major version number as there can be changes in bytecode (.mpy) format, is that correct?
Yes, we recommend matching CPY version to mpy-cross version because there are occasional breakages between versions. (We expect 7.x to be incompatible with 6.x for example.)
In general, I don't recommend using it manually though. I expect most people to use py files directly. mpy mainly optimizes the load memory of libraries.
kevinjwalters wrote:There are instructions for compiling on Building CircuitPython: Build CircuitPython and Adafruit Forums: how to precompile a .py file to a .mpy file Windows 10. Those might be a bit involved for a portion of the CircuitPython audience.
It's not a bad idea to rename it but not a priority for me because it should be rarely used directly.
tannewt
by kevinjwalters on Mon Jul 27, 2020 5:38 pm
Thanks, is there somewhere to download the mpy-cross binaries for version 5 and 6?
kevinjwalters
by danhalbert on Tue Jul 28, 2020 2:21 pm
We have not changed the .mpy format since 3.x, so the old mpy-cross compilers are still fine. We are actually building mpy-cross for various platforms, but right now they are discarded instead of being uploaded for each build. We need to add a Windows build
danhalbert
by kevinjwalters on Tue Aug 04, 2020 8:19 am
Thanks. BTW, mpy-cross gets mentioned in https://learn.adafruit.com/welcome-to-c ... -questions wrt MemoryError exceptions.
kevinjwalters
by danhalbert on Tue Aug 04, 2020 9:11 am
mpy-cross executables are now available at https://adafruit-circuit-python.s3.amaz ... mpy-cross/. Any of these will work. You can use these 6.0.0 executables for 4.x, 5.x, and 6.x.
danhalbert
